Jake8090 Posted May 12, 2014 Share Posted May 12, 2014 Hello again all. i have been using tangent constraint to constrain the ball in a ball bearing to the inner ring so as to be able to rotate the ring and balls when the outer ring is grounded. However I believe this is giving me a fixed connection and not allowing a rolling motion between the two. Can anyone suggest an alternative that will give the desired result. Many thanks Jake8090. Quote Link to comment Share on other sites More sharing options...
