Results 1 to 8 of 8
    Forum Newbie
    Civil 3D 2010
    Sep 2011
    7
    Default pline square ends
    Hello,
    Using Autocad 2013, I have created a thick dashed polyline. Is there a command available that will square each dashed end rather then having the each end rounded?
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,743
    To assign a line end or line join style
    You change that property in your plotsyle.
    Here are the results of my F1 key (AutoCad help) search on Line end.
    Click Format Plot Style.
    At the command prompt, enter stylesmanager.
    Right-click a CTB or STB file. Click Open.
    In the Plot Style Table Editor, Table View tab, click the Line End Style or Line Join Style field for the plot style you want to change.
    Select an option from the drop-down list.
    Command entry: STYLESMANAGER
    However, using square ends may result in a little notch showing on the outside corners of the thickest lines. Try the mitered corners instead. Even these can cause an anomaly, ears on the outside corners that are more than 90 degrees.
    Lines only meet at the dead center point, so the thicker, heavier the lines the more obvious the end style is.
    Round end styles are the lesser of 3 or 4 evils.
    Who sees line end styles? If your lines are so heavy that the end styles are visible, then maybe they are too thick.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,105
    How have you made your thick polylines? - with width or by lineweight?
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,743
    Yeah, then there's that ^^^^^^^^^^!
  5. #5
    Forum Newbie
    Civil 3D 2010
    Sep 2011
    7
    Thanks for the info.
  6. #6
    Forum Newbie
    Architectural
    AutoCAD 2015
    Aug 2017
    3
    This seems to be the best solution, indeed! Use PLINEWID to set the width of new lines; or select an existing line and change the "global width" in PROPERTIES.
  7. #7
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,743
    Quote Originally Posted by jornywar View Post
    Plines with width exacerbate the square end issue, not correct it, and by the way, this thread died a sudden death three years and 3 months ago.
  8. #8
    Forum Newbie
    Architectural
    AutoCAD 2015
    Aug 2017
    3
    Default a visual explanation
    Quote Originally Posted by Dana W View Post
    You know, Dana W, I did notice that this was an old thread, but it was one of the first that came up when searching for a solution, and it was the most helpful thread I found on the web to answer my question. No need to be rude about it to a newbie!
    Also, this image better explains what I'm talking about. Hope it's helpful to someone at some point.
  1. Lisp for getting Area into square meter and square millimeter
    By rengised in forum AutoLISP, Visual LISP & DCL
    Last Post: 27th Aug 2013, 06:46 pm
  2. pline, length of vertex distance from ends?
    By orange in forum AutoCAD General
    Last Post: 16th Nov 2010, 03:06 am
  3. Anything (BLOCK, LINE, PLINE, TEXT, MTEXT) Align to LINE, PLINE
    By cadamrao in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Jun 2010, 02:53 pm
  4. Tag Ends on a Polyline
    By JaketheMan in forum AutoCAD Drawing Management & Output
    Last Post: 31st Oct 2007, 08:42 pm
