Hello.
During my intership I was asked to make a VBA code to automate some actions, but I have never used AutoCAD before so I would need some help.
There are plenty of Block Reference which are devided by groups, and my objective is to select each group and make a new layer with this selection zoomed.
I'v already found how to get the position of a block reference (.InsertionPoint) and now I want to get the ID of the blocks.
Exemple :
Here I want to get "051_015_10_1726" so I know this bloc reference is from group 10.
I thought .ObjectID would do the job, but I just feel like it gives random numbers
Any advice ? :)
Get a mod to move this to Forum for .NET, ObjectARX & VBA.
Exemple :
Any advice ? :)
Welcome to CADTutor. :)
I could be mistaken, as there is no sample drawing to dig through, but it appears as though you're after the nested Attribute Object's TextString Property.
Cheers
This may be helpfull
FilterDXFCode(0) = 0
FilterDXFVal(0) = "INSERT"
'FilterDXFCode(1) = 2
'FilterDXFVal(1) = "SCHEDTEXT"
Set SS = ThisDrawing.SelectionSets.Add("pit1sel")
SS.Select acSelectionSetAll, , , FilterDXFCode, FilterDXFVal
For Cntr = 0 To SS.Count - 1
If SS.Item(Cntr).Name = BLOCK_NAME Then
  attribs = SS.Item(Cntr).GetAttributes
    If attribs(0).TextString = pitname Then
            txtx1 = CStr(FormatNumber(pt1(0), 3))
      TXTY1 = CStr(FormatNumber(pt1(1), 3))
       attribs(1).TextString = txtx1
       attribs(2).TextString = TXTY1
       attribs(1).Update
       attribs(2).Update
BlockRef.GetAttributes(0).TextString
This works perfectly.
Thank you all !
