Hello.
Here is my problem :
I want to select the Model Space either in VBA or with a Command, but I have two Model Spaces (a legend and the "real" model space) and I can't choose which one it activates with the command "_.MSPACE".
Is there a way to choose, or are the Model Spaces supposed to be unique ?
Hope you can help ! :)
After some research I found the shortcut Ctrl + R which allows to toggle between the view ports. Is there a way to do this with a command or a VBA instruction ?
Haven't found anything :(
More information is needed.
MSPACE is the correct command to active a given Viewport, and your subsequent user prompt/Command call will allow user to switch between Viewports. Otherwise you might consider the CVPORT System Variable.
Hello. :)
Here are some screens :
The drawing
What I get with .SendCommand "_.MSPACE" & vbCr
(the view port with the legend is selected)
What I want
(the view port with the map is selected)
This can be done by clicking twice on it, or with the shortcut Ctrl + R,
but I can't find a way to do this in VBA.
Awesome, thanks for "CVPORT". :D
I'm sorry my question wasn't clear enough, I should have posted screens.
Just a bit extra CTAB is the variable for the current layout so you can change to a different layout sheet easy also. CTAB "Model"
