andy_lee Posted May 17, 2014 Posted May 17, 2014 (edited) Sometimes, some routine need ET , If routine call command is "test" , so call "test" , frist, judge ET,if not installed , Pop-up prompts. Edited May 17, 2014 by andy_lee Quote
Snownut Posted May 17, 2014 Posted May 17, 2014 Just what is ET, a LISP program, .net application, need more information. Quote
ymg3 Posted May 17, 2014 Posted May 17, 2014 Snownut, Express Tools How aout simply issuing command EXPRESSTOOLS ymg Quote
andy_lee Posted May 19, 2014 Author Posted May 19, 2014 (if (findfile "acetutil.arx") Problem has been resolved! Quote
hmsilva Posted May 19, 2014 Posted May 19, 2014 (if (findfile "acetutil.arx") Problem has been resolved! andy_lee, with (if (findfile "acetutil.arx") you are only testing the file existence at your system, to test if loaded, try (if (member "acetutil.arx" (arx)) HTH Henrique Quote
andy_lee Posted May 19, 2014 Author Posted May 19, 2014 andy_lee,with (if (findfile "acetutil.arx") you are only testing the file existence at your system, to test if loaded, try (if (member "acetutil.arx" (arx)) HTH Henrique Thank you so much!hmsilva, That's good! Quote
hmsilva Posted May 19, 2014 Posted May 19, 2014 You're welcome, andy lee! Glad I could help Henrique Quote
andy_lee Posted May 19, 2014 Author Posted May 19, 2014 You're welcome, andy lee!Glad I could help Henrique Good friend! Could like this (if (or (member "acetutil.arx" (arx)) (and (findfile "acetutil.arx")(arxload "acetutil.arx"))) Quote
hmsilva Posted May 19, 2014 Posted May 19, 2014 Maybe something like this (if (not (member "acetutil.arx" (arx)));; test if loaded (if (findfile "acetutil.arx");; if not, test if find (arxload "acetutil.arx");; if find, load (prompt "\n\"acetutil.arx\" wasn't found on the system!!!");; prompt ) (prompt "\n\"acetutil.arx\" was already loaded!!!");; prompt ) HTH Henrique Quote
andy_lee Posted May 19, 2014 Author Posted May 19, 2014 Maybe something like this (if (not (member "acetutil.arx" (arx)));; test if loaded (if (findfile "acetutil.arx");; if not, test if find (arxload "acetutil.arx");; if find, load (prompt "\n\"acetutil.arx\" wasn't found on the system!!!");; prompt ) (prompt "\n\"acetutil.arx\" was already loaded!!!");; prompt ) HTH Henrique Without such redundancy . Thank a lot! Quote
ReMark Posted May 19, 2014 Posted May 19, 2014 Whatever happened to looking at your screen or is that too taxing? Quote
hmsilva Posted May 19, 2014 Posted May 19, 2014 Without such redundancy . Thank a lot! andy lee, it's not redundancy, is just a way to get feedback from the test function... Henrique Quote
