MikeR Posted May 19, 2014 Share Posted May 19, 2014 If I am plotting a property description, and the next call is a 2degree curve to the left, at a distance of 600'. How do I go about plotting that? Quote Link to comment Share on other sites More sharing options...
JD Mather Posted May 19, 2014 Share Posted May 19, 2014 I suspect you have more information than you have provided here. Can you delete most of the file and then attach the area of concern here? Quote Link to comment Share on other sites More sharing options...
zaphod Posted May 19, 2014 Share Posted May 19, 2014 this might help, draw a line straight with Ortho on 600' rotate it 2 degrees, use the polyline (PL) command, after you pick the start point (end point of the rotated line), select Arc (A), then pick the other end point. their are other possible ways but this was the first I could think of. Quote Link to comment Share on other sites More sharing options...
