Hi everyone, I just wanted to ask could anyone fix this lisp?
I've found it on autocadtips website and I hope it won't be hard to fix it.
I'm currently using split dimensions lisp and I've looked for opposite function (join dimensions) but this is the only lisp routine I could find.
;Shusei Hayashi
;OffshoreCad&Management Inc.
;10F Jaka Bldg., 6780 Ayala Ave.,
;Makati, Philippines
;http://www.offshorecad.com.ph/
;http://www.offshore-management.com.ph/
; Modified by Greg Battin
; Featured @ www.autocadtips.wordpress.com
(defun c:JDIMS (/ Flag ObjName1 ObjName2 Ang Ang2 Pt1 Pt2 Pt3 Pt4)
 (princ
   "\n convert two dimensions to total Dimension on the same position"
 (princ "\n **********************************")
 (setq *error* *myerror*)
 (SD1028)
 (setq LegLen 7.0)
 (setq Flag nil)
 (get_layer&ltype&color)
 (RegistryRead_1001)
 (setvar "Clayer" Lay1)
 (setvar "Cecolor" Col1)
 (setvar "Celtype" LT1)
 (while (= Flag nil)
   (setq ObjName1 (car (entsel "\n Select 1st Dimension :")))
   (if	(and ObjName1
     (=	(cdr (assoc 0 (setq Data1 (entget ObjName1))))
	"DIMENSION"
     (setq Flag T)
 (redraw ObjName1 3)
 (setq theStyle (SD3511 3 ObjName1))
 (setq Flag nil)
 (while (= Flag nil)
   (setq ObjName2 (car (entsel "\n Select 2nd Dimension :")))
   (if
     (and
ObjName2
(= (cdr (assoc 0 (setq Data2 (entget ObjName2))))
   "DIMENSION"
(or
  (equal (abs (- (cdr (assoc 50 Data1)) (cdr (assoc 50 Data2))))
	 0.0
	 0.0001
	 pi
	 0.0001
      (setq Flag T)
      (princ "\n two dimensions should have same angle")
 (redraw ObjName1 4)
 (setq	PList (list (cdr (assoc 13 Data1))
	    (cdr (assoc 14 Data1))
	    (cdr (assoc 13 Data2))
	    (cdr (assoc 14 Data2))
 (setq PList2 (list (cdr (assoc 10 Data1)) (cdr (assoc 10 Data2))))
 (if (/= (distance (cdr (assoc 14 Data1)) (cdr (assoc 10 Data1)))
  0
   (setq Ang (angle (cdr (assoc 14 Data1)) (cdr (assoc 10 Data1))))
   (setq Ang (+ (angle (cdr (assoc 13 Data1)) (cdr (assoc 14 Data1)))
	 (* 0.5 pi)
 (setq Ang2 (+ Ang (* -0.5 pi)))
 (setq ItsLayer (cdr (assoc 8 Data1)))
 (setq PList_n (mapcar '(lambda (x) (SD1862 x Ang2)) PList))
 (setq PList2_n (mapcar '(lambda (x) (SD1862 x Ang2)) PList2))
 (setq PList_n_x (mapcar 'car PList_n))
 (setq PList2_n_y (mapcar 'cadr PList2_n))
 (setq Position1 (vl-position (apply 'min PList_n_x) PList_n_x))
 (setq Position2 (vl-position (apply 'max PList_n_x) PList_n_x))
 (setq Position3 (vl-position (apply 'max PList2_n_y) PList2_n_y))
 (setq Pt1 (nth Position1 PList))
 (checkcircle Pt1 1.0 "A21")
 (setq Pt2 (nth Position2 PList))
 (checkcircle Pt2 1.0 "A31")
 (setq Pt3 (nth Position3 PList2))
 (checkcircle Pt3 1.0 "A51")
 (setq Pt4 (polar Pt3 Ang (* LegLen Scale)))
 (checkcircle Pt4 1.0 "A21")
 (setq	Pt1 (trans Pt1 0 1)
Pt2 (trans Pt2 0 1)
Pt3 (trans Pt3 0 1)
Pt4 (trans Pt4 0 1)
 (setq UAng (angle '(0 0) (getvar "UCSXDIR")))
 (setq Ang2 (- Ang2 UAng))
 (command "._dimstyle" "RE" theStyle)
 (command "dimrotated" (* 180 (/ Ang2 pi)) Pt1 Pt2 Pt3)
 (command "change" (entlast) "" "P" "LA" ItsLayer "")
 (entdel ObjName1)
 (entdel ObjName2)
 (SD2056)
 (setq *error* nil)
(defun RegistryRead_1001 ()
 (setq Path1001 "HKEY_CURRENT_USER\\Software\\SpeedDraftLT\\SD_1001")
 (if (vl-registry-read Path1001 "LegLen")
   (progn (set_tile "LegLen" (vl-registry-read Path1001 "LegLen"))
   (setq LegLen (atof (vl-registry-read Path1001 "LegLen")))
   (setq LegLen 7.0)
 (if (and (vl-registry-read Path1001 "Lay1")
   (member (vl-registry-read Path1001 "Lay1") Laylist1)
   (progn (set_tile
     "Lay1"
     (itoa
       (vl-position (vl-registry-read Path1001 "Lay1") Laylist1)
   (setq Lay1 (vl-registry-read Path1001 "Lay1"))
   (progn (setq Lay1 (getvar "Clayer"))
   (set_tile "Lay1" (itoa (vl-position Lay1 Laylist1)))
 (if (and (vl-registry-read Path1001 "LT1")
   (member (vl-registry-read Path1001 "LT1") Laylist3)
   (progn (set_tile
     "LT1"
     (itoa
       (vl-position (vl-registry-read Path1001 "LT1") Laylist3)
   (setq LT1 (vl-registry-read Path1001 "LT1"))
   (progn (setq LT1 "ByLayer") (set_tile "LT1" "0"))
 (if (and (vl-registry-read Path1001 "Col1")
   (member (vl-registry-read Path1001 "Col1") Laylist2)
   (progn (set_tile
     "Col1"
     (itoa
       (vl-position (vl-registry-read Path1001 "Col1") Laylist2)
   (setq Col1 (vl-registry-read Path1001 "Col1"))
   (progn (setq Col1 "ByLayer") (set_tile "Col1" "0"))
(defun SD1028 ()
 (setq OldCmdEcho (getvar "CMDECHO"))
 (setvar "CMDECHO" 0)
 (command "undo" "be")
 (setq OldOsmode (getvar "OSMODE"))
 (setq OldLayer (getvar "CLAYER"))
 (setq OldLType (getvar "CeLType"))
 (setq OldCeLWeight (getvar "CeLWeight"))
 (setq OldColor (getvar "CeColor"))
 (setq OldOrtho (getvar "ORTHOMODE"))
 (setq OldDStyle (getvar "DIMSTYLE"))
 (setq OldExpert (getvar "Expert"))
 (setvar "EXPERT" 0)
 (setq Path_Lang "HKEY_CURRENT_USER\\Software\\SpeedDraftLT")
(defun SD2056 ()
 (setvar "OSMODE" OldOsmode)
 (command "undo" "end")
 (setvar "CLAYER" OldLayer)
 (setvar "CeLType" OldLType)
 (setvar "CeLWeight" OldCeLWeight)
 (setvar "CeColor" OldColor)
 (setvar "ORTHOMODE" OldOrtho)
 (setvar "Expert" OldExpert)
 (if (and (/= (getvar "DIMSTYLE") OldDStyle)
   (tblsearch "DIMSTYLE" OldDStyle)
   (command "-dimstyle" "Restore" OldDStyle)
 (setvar "CMDECHO" OldCmdEcho)
(defun get_layer&ltype&color ()
 (setq	Lay	 (tblnext "LAYER" T)
LT	 (tblnext "LTYPE" T)
Laylist1 (list)
Laylist2 (list "ByLayer"  "Red"	     "Yellow"	"Green"
	       "Cyan"	  "Blue"     "Magenta"	"B/W"
Laylist3 (list "ByLayer")
 (While Lay
   (setq lay1	   (list (cdr (assoc 2 Lay)))
  lay2	   (cdr (assoc 62 Lay))
  lay3	   (list (cdr (assoc 6 Lay)))
  Laylist1 (append Laylist1 lay1)
  Laylist3 (append Laylist3 lay3)
  Lay	   (tblnext "LAYER")
   (if	(> lay2 7)
     (setq lay2     (list (itoa lay2))
    Laylist2 (append Laylist2 lay2)
 (While LT
   (setq lay3	   (list (cdr (assoc 2 LT)))
  LT	   (tblnext "LTYPE")
 (setq	Laylist1 (RemoveOverlap Laylist1)
Laylist2 (RemoveOverlap Laylist2)
Laylist3 (RemoveOverlap Laylist3)
(defun RemoveOverlap (List2 / List1)
 (while List2
   (setq List1 (append List1 (list (car List2))))
   (setq List2 (vl-remove (car List2) List2))
 List1
;;;---------Rotate----------------------------
(defun SD8446 (PointA PointB Ang / XA YA XB YB PointC)
 (setq	XA2 (- (car PointA) (car PointB))
YA2 (- (cadr PointA) (cadr PointB))
 (setq	PointC (list (- (* XA2 (cos Ang)) (* YA2 (sin Ang)))
	     (+ (* XA2 (sin Ang)) (* YA2 (cos Ang)))
 (setq PointC (mapcar '+ PointC PointB))
 PointC
(defun SD1862 (OldPt Ang / NewCs)
 (setq NewCs (SD8446 '(1 0) '(0 0) Ang))
 (setq NewPt (trans OldPt 0 NewCs))
 (setq NewPt (list (nth 2 NewPt) (nth 0 NewPt)))
 NewPt
(defun SD3511 (g e)
 (cond
   ((= (type e) 'ename) (cdr (assoc g (entget e))))
   ((= (type e) 'list) (cdr (assoc g e)))
(defun *myerror* (msg)
 (setq *error* nil)
 (SD2056)
 (princ "\n Error in SpeedDraftLT")
(princ "\n Command Name: JDIMS")
Here's a version that has been very had very minimal clean up from the version that I posted on my blog. I don't have my computer that has 2014 & 2015 on it so i cant test this version.
Is this any better?
(In the version I posted on the blog, I cleaned up some of the gibberish symbols and also the language check... In the version posted below I left everything intact but I did comment-out the language check. I also checked this version in 2013 and it worked)
*Update - Just tried the below code in Vanilla ACAD 2015 and it worked.
~Greg
;“ñ‚‚̓¯‚¶ŒX‚«‚ðŽ‚Á‚½¡–@‚ðŽwަ‚µA‚»‚̍‡Œv¡–@‚ð‚»‚ÌêŠ‚ɏ‘‚*
;Å‰‚ÉŽwަ‚µ‚½2‚‚̐¡–@‚͏Á‚¦‚é
;UCS‘Ήž
;Shusei Hayashi
(defun c:SD_1005( /  Flag ObjName1 ObjName2 Ang Ang2 Pt1 Pt2 Pt3 Pt4)
;	(if (= SD:Lang "E")
	(princ "\n convert two dimensions to total Dimension on the same position")
;		(princ "\n “ñ‚‚̐¡–@‚ðŽwަ‚µA‚»‚̍‡Œv¡–@‚ð‚»‚ÌêŠ‚ɏ‘‚*")
(SD1028)
(setq LegLen 7.0)
(setq Flag nil)
(RegistryRead_1001)
(while (= Flag nil)
;			(setq ObjName1 (car (entsel "\n Å‰‚̐¡–@‚ðŽwަF ")))
	(if (and ObjName1(= (cdr (assoc 0 (setq Data1 (entget ObjName1)))) "DIMENSION"))
		(setq Flag T)
(redraw ObjName1 3)
(setq Flag nil)
(while (= Flag nil)
;			(setq ObjName2 (car (entsel "\n 2‚–ڂ̐¡–@‚ðŽwަF ")))
	(if 	(and 	ObjName2
			(= (cdr (assoc 0 (setq Data2 (entget ObjName2)))) "DIMENSION")
			(or	(equal (abs (- (cdr (assoc 50 Data1))(cdr (assoc 50 Data2)))) 0.0 0.0001)
				(equal (abs (- (cdr (assoc 50 Data1))(cdr (assoc 50 Data2)))) pi 0.0001)
		(setq Flag T)
;				(princ "\n 2‚‚̐¡–@‚Í“¯‚¶Šp“x‚łȂ¯‚ê‚΂¢‚¯‚Ü‚¹‚ñ")
(redraw ObjName1 4)
;‘«‚̐æ‚Ì4“_
(setq PList (list (cdr (assoc 13 Data1))(cdr (assoc 14 Data1))(cdr (assoc 13 Data2))(cdr (assoc 14 Data2))))
;¡–@ˆÊ’u‚Ì2“_
;‘«‚©‚ç—§‚¿ã‚ª‚éŠp“x
(if (/= (distance (cdr (assoc 14 Data1))(cdr (assoc 10 Data1))) 0)
	(setq Ang (angle (cdr (assoc 14 Data1))(cdr (assoc 10 Data1))))
	(setq Ang (+ (angle (cdr (assoc 13 Data1))(cdr (assoc 14 Data1))) (* 0.5 pi)))
(setq Ang2 (+ Ang (* -0.5 pi)))	;‚í‚©‚è‚â‚·‚¢‚悤‚ɉE‚Ö90“x‚܂킷
;ƒŒƒCƒ„[
;¡–@‚ÌŒX‚«‚ɍ‡‚킹‚½À•WŒn‚ɕϊ·
(setq PList_n (mapcar '(lambda(x)(SD1862 x Ang2))PList))
(setq PList2_n (mapcar '(lambda(x)(SD1862 x Ang2))PList2))
;xÀ•W‚¾‚¯W‚ß‚é
;yÀ•W‚¾‚¯W‚ß‚é
;Å¬’l‚̈ʒu
;Å‘å’l‚̈ʒu
;Å‘å’l‚̈ʒu
;	(checkcircle Pt1 1.0 "A21")
;	(checkcircle Pt2 1.0 "A31")
;	(checkcircle Pt3 1.0 "A51")
;	(setq Pt4 (polar Pt3 Ang (* LegLen Scale)))
;	(checkcircle Pt4 1.0 "A21")
		Pt2 (trans Pt2 0 1)
		Pt3 (trans Pt3 0 1)
;			Pt4 (trans Pt4 0 1)
(entdel ObjName1)(entdel ObjName2)
(SD2056)
(setq *error* nil)
;ƒŒƒWƒXƒgƒŠ‚©‚çƒf[ƒ^‚ðŽæ“¾-----------------------------------------
(defun RegistryRead_1001()
(if (vl-registry-read Path1001 "LegLen" )
			(setq LegLen (atof (vl-registry-read Path1001 "LegLen")))		;‘«‚Ì’·‚³
	(setq LegLen 7.0)		;ƒŒƒWƒXƒgƒŠ‚É’l‚ª–³‚¢ê‡
(if (and (vl-registry-read Path1001 "Lay1" )(member (vl-registry-read Path1001 "Lay1") Laylist1))
	(progn 	(set_tile "Lay1" (itoa (vl-position (vl-registry-read Path1001 "Lay1") Laylist1)))
	(progn 	(setq Lay1 (getvar "Clayer"))(set_tile "Lay1" (itoa (vl-position Lay1 Laylist1))))
(if (and (vl-registry-read Path1001 "LT1" )(member (vl-registry-read Path1001 "LT1") Laylist3))
	(progn 	(set_tile "LT1" (itoa (vl-position (vl-registry-read Path1001 "LT1") Laylist3)))
	(progn 	(setq LT1 "ByLayer")(set_tile "LT1" "0"))
(if (and (vl-registry-read Path1001 "Col1" )(member (vl-registry-read Path1001 "Col1") Laylist2))
	(progn 	(set_tile "Col1" (itoa (vl-position (vl-registry-read Path1001 "Col1") Laylist2)))
	(progn 	(setq Col1 "ByLayer")(set_tile "Col1" "0"))
;‹¤’ʃRƒ}ƒ“ƒh
(defun SD1028 ()
 (setvar "EXPERT" 0)
;  (if (vl-registry-read Path_Lang "SD_Language" )
;  	(setq SD:Lang (vl-registry-read Path_Lang "SD_Language" ))
;  	(progn	(setq SD:Lang "J")
;  			(vl-registry-write Path_Lang "SD_Language" "J")
(defun SD2056 ()
 (if (and (/= (getvar "DIMSTYLE") OldDStyle)(tblsearch "DIMSTYLE" OldDStyle))
 (princ "\n (C)OffshoreCad&Management")
(defun get_layer&ltype&color()
		Laylist1 (list)
		Laylist2 (list "ByLayer" "Red" "Yellow" "Green" "Cyan" "Blue" "Magenta" "B/W")
		Laylist3 (list"ByLayer")
(While Lay
  	(if (> lay2 7)(setq  lay2 (list (itoa lay2)) Laylist2 (append Laylist2 lay2)))
(While LT
		Laylist3 (RemoveOverlap Laylist3))
(defun RemoveOverlap (	List2	/	List1	)
(while List2
List1
;;;“_A‚ð“_B‚𒆐S‚Ƀ¿‚¾‚¯‰ñ“]‚³‚¹‚½À•W
;;;yˆø‚«”z“_A ’†S Šp“xƒ¿
;;;y–ß‚è’lz“_C
(defun SD8446 ( PointA PointB Ang / XA YA XB YB PointC)
(setq 	XA2(- (car PointA) (car PointB))
		YA2(- (cadr PointA) (cadr PointB))
(setq PointC (list (- (* XA2 (cos Ang))(* YA2 (sin Ang))) (+ (* XA2 (sin Ang))(* YA2 (cos Ang)))))
PointC
;À•WŒn•ÏŠ·iAng‚¾‚¯Œ´“_Žü‚è‚ɉñ“]‚µ‚½À•WŒn‚Å•\Œ»‚·‚é
(setq NewPt (list (nth 2 NewPt)(nth 0 NewPt)))
NewPt
(defun SD3511 (g e)
(cond
(setq *error* nil)
(SD2056)
(if (= SD:Lang "E")
(princ "\n Command Name: SD_1005")
(princ "\n ƒRƒ}ƒ“ƒh–¼FSD_1005")
Edited by troggarf
Thank you, Greg! It worked on AutoCAD 2014 aswell, this is a quite handy function for me.
Now I'll continue working on my projects :)
  • 7 years later...
Hi. Can any one fix the code to work with the example in the attached file, because
1) when join the dimensions then rotated them
2) Change the text size
Thanks
tet.dwg
