Results 1 to 4 of 4
    Forum Newbie
    AutoCAD 2012
    May 2014
    2
    Default How do I convert a 'dynamic' furniture block to standard object
    Once I have selected all my seating, dining and bed sizes and seat numbers dynamically from a block dropdown list, how do I convert them to standard drawing elements.
    When I go to export my floorplan to DWG/DXF for import into Illustrator I get all the different furniture objects all pile don top of each other. Such as a chair, loveseat, 3 cushion and 4 cushion all centered on top of each other.
    I would like to collapse all the 'smart', 'dynamic', 'parametric' elements out so I get what I am looking at, not all the hidden drawings that make up the dynamic selection.
    Would love to do this globally, or with selection set but can do individually if need be. Explode does not work (even with 'allow explode' on for the block) And going into block editor and changing visibility of all other unwanted blocks doesn't get rid of them either.
    Ron
    Super Member
    AutoCAD 2012
    Jun 2012
    902
    Welcome to the forum, Ron. When you say Explode does not work, do you mean you are unable to Explode the blocks, even with the explode option allowed? Something sounds amiss there.
    BTW, if you are able to upload the drawing with the blocks you are dealing with, that will likely be the easiest way to solve the problem for you.
    When all you have is a hammer, everything looks like a nail.--
    “Doc, it hurts when I do this.” “Well, don’t do that!”
    “Well, if you don’t know, I’m certainly not going to tell you!”
    Forum Newbie
    AutoCAD 2012
    May 2014
    2
    Default yes, that is what I mean
    I have attached 2 of the pieces. It says I cannot explode these. I am looking at the 'allow explode' checkbox when I hit 'B' command.
    I don't know if I necessarily need to explode them. What I need is for them not to export as all the block versions pile don top of each other.
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,877
    Open the Block in Block Editor and do not select anything, go to Properties and in section Block set Allow Exploding to Yes. Save the changes and explode the blocks when you have them set to where you want, you can explode again if you want or need to.
    See if this thread with some code for exploding blocks from Lee Mac helps. http://www.cadtutor.net/forum/showth...654#post359654
  1. Keeping an object centered and stretched in dynamic block
    By artuiel in forum AutoCAD Drawing Management & Output
    Last Post: 25th Mar 2014, 05:41 pm
  2. change dynamic block into standard block
    By cadamrao in forum AutoLISP, Visual LISP & DCL
    Last Post: 11th May 2010, 10:06 am
  3. dynamic blocks convert into standard blocks
    Last Post: 10th May 2010, 03:41 pm
  4. Dynamic Block - changing object color
    By dvjstyles in forum AutoCAD Drawing Management & Output
    Last Post: 5th Jan 2009, 02:11 pm
  5. Convert Layers to Standard
    By Rhayes in forum AutoCAD Drawing Management & Output
    Last Post: 18th Sep 2007, 09:40 pm
