cadmando2 Posted June 3, 2014 Share Posted June 3, 2014 I created blocks on 0 layer, after inserting them into a dwg, i selected them to changing the properties to different layer e-plc-panel color 8 gray. It change the that layer, but wouldn't change to the layer color. I even tried inserting them under the e-plc-panel layer and still kept the color white. It SHOW IN THE PROPERTIES THAT IS WHAT EVER COLOR YOU WANT OR BYLAYER TO BYBLOCK AND THE BLOCKS KEEP THE SHOWING UP AS WHITE? I am using autocad electrical 2014. I used to be able to do that. Quote Link to comment Share on other sites More sharing options...
cadmando2 Posted June 3, 2014 Author Share Posted June 3, 2014 Forgot how to delete a post. Issue resolved Quote Link to comment Share on other sites More sharing options...
RobDraw Posted June 4, 2014 Share Posted June 4, 2014 Rather than delete, you should post your solution so that others may benefit from your learning. Quote Link to comment Share on other sites More sharing options...
