Andrew1979 Posted June 4, 2014 Posted June 4, 2014 I have created a .mnu file which I can load into AutoCAD fine, and it all works. Once I close AutoCAD and reopen it, the menu is gone. If I type menuload, the menu name is there, it just doesn't show on the menu bar. here is the menu code: ***MENUGROUP=TrussCAD ***POP35 [TrussCAD] [Roof Truss A Frame Elevation]^c^c(load "c:/Program Files/Truss CAD/RoofTruss.vlx");_rtruss; [Roof Truss Mono Elevation]^c^c(load "c:/Program Files/Truss CAD/RoofTrussMono.vlx");_mtruss; [Roof Truss Scissor Elevation]^c^c(load "c:/Program Files/Truss CAD/RoofTrussScissor.vlx");_struss; [Roof Truss Mono Scissor Elevation]^c^c(load "c:/Program Files/Truss CAD/RoofTrussScissorMono.vlx");_smtruss; [Roof Truss Section]^c^c(load "c:/Program Files/Truss CAD/RoofTrussTimberSection.vlx");_rtrusssect; [--] [Floor Truss Elevation]^c^c(load "c:/Program Files/Truss CAD/FloorTrussTimber.vlx");_ftruss; [Floor Truss Section]^c^c(load "c:/Program Files/Truss CAD/FloorTrussTimberSection.vlx");_ftjoist; [--] [Tile Roof & Battens]^c^c(load "c:/Program Files/Truss CAD/RoofBattensTile.vlx");_rbt; [sheet Roof & Battens]^c^c(load "c:/Program Files/Truss CAD/RoofBattensSheet.vlx");_rbs; [--] [->Colour Defaults] [Nailplate]^c^c(load "c:/Program Files/Truss CAD/UpdateColours.vlx");_TrussColNailPlate; [Truss Elevation]^c^c(load "c:/Program Files/Truss CAD/UpdateColours.vlx");_TrussCol; [<-Truss Section]^c^c(load "c:/Program Files/Truss CAD/UpdateColours.vlx");_TrussColSect; [About]^c^c(load "c:/Program Files/Truss CAD/TC-About.vlx");TC-About; [Help]^c^cbrowser;"[url]file:///c:/Program[/url] Files/Truss CAD/Help.html"; [--] [setup]^c^c(load "c:/Program Files/Truss CAD/TC-Setup.vlx");TC-setup; ***TOOLBARS **TrussCAD ID_1 [_Toolbar("TrussCAD", _Floating, _Show, 202, 151, 1)] ID_2 [_Button("Roof Truss A Frame", "TC-RoofTrussA16.png", "TC-RoofTrussA32.png")]^c^c(load "c:/Program Files/Truss CAD/RoofTruss.vlx");_rtruss; ID_3 [_Button("Roof Truss Mono", "TC-RoofTrussMono16.png", "TC-RoofTrussMono32.png")]^c^c(load "c:/Program Files/Truss CAD/RoofTrussMono.vlx");_mtruss; ID_4 [_Button("Roof Truss Scissor", "TC-RoofTrussScissor16.png", "TC-RoofTrussScissor32.png")]^c^c(load "c:/Program Files/Truss CAD/RoofTrussScissor.vlx");_struss; ID_5 [_Button("Roof Truss Mono Scissor", "TC-RoofTrussMonoScissor16.png", "TC-RoofTrussMonoScissor32.png")]^c^c(load "c:/Program Files/Truss CAD/RoofTrussScissorMono.vlx");_smtruss; ID_6 [_Button("Roof Truss Section", "TC-RT-SECT16.png", "TC-RT-SECT32.png")]^c^c(load "c:/Program Files/Truss CAD/RoofTrussTimberSection.vlx");_rtrusssect; ID_7 [_Button("Floor Truss Timber", "TC-FloorTruss16.png", "TC-FloorTruss32.png")]^c^c(load "c:/Program Files/Truss CAD/FloorTrussTimber.vlx");_ftruss; ID_8 [_Button("Floor Truss Section", "TC-FT-SECT16.png", "TC-FT-SECT32.png")]^c^c(load "c:/Program Files/Truss CAD/FloorTrussTimberSection.vlx");_ftjoist; ID_9 [_Button("Tile Roof Battens", "TC-RBT16.png", "TC-RBT32.png")]^c^c(load "c:/Program Files/Truss CAD/RoofBattensTile.vlx");_rbt; ID_10 [_Button("Sheet Roof Battens", "TC-RBS16.png", "TC-RBS32.png")]^c^c(load "c:/Program Files/Truss CAD/RoofBattensSheet.vlx");_rbs; Quote
Andrew1979 Posted June 4, 2014 Author Posted June 4, 2014 its ok, I worked it out. For some reason there was another cuix file in the support folder that was conflicting. Deleted it and no problems Quote
BIGAL Posted June 5, 2014 Posted June 5, 2014 Watch out for workspaces set to NO SAVE changes also you load new menu close then its gone. I always manually resave my workspace but have it set to No save like on the others so no stuff ups by the guys here. Quote
BIGAL Posted June 5, 2014 Posted June 5, 2014 Its an option in the workspace down bottom right just pick icon, stuff like change workspace, save etc no cad at moment. Quote
