Extrusion failure
Vagulus
Always check around the profile to see that there are no irregularities such as overlapping curves etc. You had a couple that should have been trimmed back, after that it extruded no problem.
Why are there dimensions on your sketch that aren't in the book?
You can reduce sketch clutter by using Equal (=) constraints.
Dimension same as in book as these dimensions can later be retrieved when creating 2D drawings.
(and trim construction lines)
Edited by JD Mather
