semperfudge Posted June 19, 2014 Share Posted June 19, 2014 So I'm running c3d 2013 on a win7 64x machine. When I open my drawing I see the text broken reference to aeccdbalignment... Then I go into toolspace, find my offending alignment, rightclick and choose 'repair' i get the message object not found What my problem is when I go into my source drawing is that the alignment is there and is unchanged. When I go to data shortcuts I can create references to that same alignment just fine but what I really need to do is find a way to restore the original alignment because I have a bunch of profile views that reference it. Is this possible or am i SOL? Quote Link to comment Share on other sites More sharing options...
JerryG Posted June 23, 2014 Share Posted June 23, 2014 If the profile still shows your design elevation - such as for a roadway, existing ground etc then your alignment is still there. It may be on a off layer??? If not then the alignment has been exploded and will need to be recreated. Quote Link to comment Share on other sites More sharing options...
