Bill Tillman Posted June 24, 2014 Share Posted June 24, 2014 (edited) Can anyone point me in the right direction to find out how to populate the drawing properties fields using LISP or is this a task better handled by .NET method? By drawing properties I am referring to when you select the File menu and choose Drawing Properties. I see that is uses the command _dwgprops and now I'd like to find information on how to populate the fields like "Author" "Keywords" as well as to create and populate some custom fields. Edited October 5, 2021 by Bill Tillman Quote Link to comment Share on other sites More sharing options...
Bill Tillman Posted June 24, 2014 Author Share Posted June 24, 2014 I hate to update my own posts but it's been another one of those frustrating days or searching and finding BS answers, empty answers, no answers, answers that don't work or don't include all the needed info...and all from some *&^% who thinks the whole world should know as much about the question as they do. Anyway, AfraLISP had a promising block of code...but it too would not work reporting back error after error...Wrong DXF code, etc.. But I did at least find this so for those who'd like at least something to get started with this topic: (defun addsummaryinfo (/ suminfo) (setq suminfo (vla-get-summaryinfo (vla-get-activedocument (vlax-get-acad-object) ) ) ) (vla-put-author suminfo (getenv "username")) (vla-put-comments suminfo "These are the comments") (vla-put-hyperlinkbase suminfo "") (vla-put-keywords suminfo "These are the keywords") (vla-put-lastsavedby suminfo (getenv "username")) (vla-put-revisionnumber suminfo "123456") (vla-put-subject suminfo "This is the subject") (vla-put-title suminfo (strcat (getvar 'dwgprefix) (getvar 'dwgname)) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 25, 2014 Share Posted June 25, 2014 Maybe helpfull for something (vlax-Dump-Object (vla-get-summaryinfo (vla-get-activedocument (vlax-get-acad-object) ) ) ) Quote Link to comment Share on other sites More sharing options...
dbroada Posted June 25, 2014 Share Posted June 25, 2014 I'll offer this as a no answer at all. I have used this in VBA to populate the custom properties. There may be something in it to give you a clue. Private Sub cmdUpdate_Click() Dim Key0 As String Dim Value0 As String Dim Key1 As String Dim Value1 As String Dim CustomProperty1 As String Dim Property1Value As String Dim CustomProperty2 As String Dim Property2Value As String CustomProperty1 = "RigName" Property1Value = txtRigName.Text CustomProperty2 = "STL_Number" Property2Value = txtSTL_Number.Text Key0 = CustomProperty1 ThisDrawing.SummaryInfo.SetCustomByKey CustomProperty1, Property1Value Key1 = CustomProperty2 ThisDrawing.SummaryInfo.SetCustomByKey CustomProperty2, Property2Value Me.Hide End Sub It is a long time since I last looked at this code. I was using it to prove we could speed up production of some similar produces but apparently it was too difficult to do it my way. Far better to throw people at the task. Quote Link to comment Share on other sites More sharing options...
hmsilva Posted June 25, 2014 Share Posted June 25, 2014 It may help ;; get the summaryinfo object (setq suminfo (vla-get-SummaryInfo (vla-get-ActiveDocument (vlax-get-acad-object)) ) ) ;; get the summary infos (foreach prop '(Author Comments Hyperlinkbase Keywords LastSavedBy RevisionNumber Subject Title ) (setq PropLst (cons (list prop (vlax-get-property suminfo prop)) PropLst)) ) ;; get custom infos (if (> (setq n (vla-NumCustomInfo suminfo)) 0) (repeat n (vla-GetCustomByIndex suminfo (setq n (1- n)) 'a 'b) (setq PropLst (cons (list n a b) PropLst)) ) ) ;; reverse the PropLst to the correct order (setq PropLst (reverse PropLst)) ;; remove summary infos (foreach prop '(Author Comments Hyperlinkbase Keywords LastSavedBy RevisionNumber Subject Title ) (vlax-put-property suminfo prop "") ) ;; remove custom infos (repeat (setq n (vla-NumCustomInfo suminfo)) (vla-RemoveCustomByIndex suminfo (setq n (1- n))) ) ;; set summary info (vlax-put-property suminfo TheProperty "The prop string") ;; add custom info (vla-AddCustomInfo suminfo "Prop" "The prop value") ;; set custom info by index (vla-SetCustomByIndex suminfo 0 "Prop" "The prop value") ;; set custom info by Key (vla-SetCustomByKey suminfo "Prop" "New prop value") ;; get custom info by index (vla-GetCustomByIndex suminfo 0 "Prop" 'a) ;; get custom info by Key (vla-GetCustomByKey suminfo "Prop" 'a) Henrique Quote Link to comment Share on other sites More sharing options...
nolex Posted June 23, 2021 Share Posted June 23, 2021 How do you guys run this code? Can this still be loaded through appload command in autocad? Quote Link to comment Share on other sites More sharing options...
mhupp Posted June 23, 2021 Share Posted June 23, 2021 (edited) 10 hours ago, nolex said: How do you guys run this code? Can this still be loaded through appload command in autocad? Hmsilva didn't post a complete lips code just examples for Bill to use. dbroada posted vba code that i think you need to install a VBA add-in to use inside AutoCAD. What are you looking to do? --edit this might be what your looking for https://adndevblog.typepad.com/autocad/2012/08/lisp-example-for-setting-and-getting-drawing-properties.html Edited June 23, 2021 by mhupp website 1 Quote Link to comment Share on other sites More sharing options...
