gotchy Posted July 9, 2014 Share Posted July 9, 2014 Is there a way to extrude a rectangle, for example, and having two of the 4 sides extrude on an angle, and the other two remain straight? Thank you, gotchy Quote Link to comment Share on other sites More sharing options...
JD Mather Posted July 9, 2014 Share Posted July 9, 2014 Add Face Draft after the Extrusion or Loft is a way to do it in one feature. The answer to your question is No! Unless you already have geometry - in which case the Rib command (with draft) might do it in one feature. Quote Link to comment Share on other sites More sharing options...
gotchy Posted July 10, 2014 Author Share Posted July 10, 2014 Thank you for your reply gotchy Quote Link to comment Share on other sites More sharing options...
