Jake8090 Posted July 17, 2014 Share Posted July 17, 2014 Could someone please advise. Is Projected views available in paper space in the later versions of autocad. Similar to autodesk Inventor. If so how do I activate the procedure. Many thanks Jake8090 Quote Link to comment Share on other sites More sharing options...
Dadgad Posted July 17, 2014 Share Posted July 17, 2014 (edited) Yes associative projected model views are available and to start the process, you will use the VIEWBASE command. They were introduced in Autocad in 2012. You will not need a viewport, as it sounds like you already know, if you are familiar with them in Inventor. You may need to adjust your Drafting Standard as shown in the image for Projection type you wish to use. You can right click on the model tab or any layout tab to access this dialog. Edited July 18, 2014 by Dadgad Quote Link to comment Share on other sites More sharing options...
Jake8090 Posted July 17, 2014 Author Share Posted July 17, 2014 Many Thanks Dadgad. Not tried it yet but will let you know how I get on Jake8090. Quote Link to comment Share on other sites More sharing options...
