Programmatically Rename Block with Autolisp - Help required.
Quick Background - I am so close to finishing my routine that will mass update our title block drawings from old company to new company. However in our mass library of drawings consist different title blocks names. Luckily they all touch the corner 0,0 so what I want to do is update this piece of code shown below to instead of asking the user to select the block is to programmatically select what ever is on 0,0.
In autocad I can enter at the command line (entsel) then 0,0 and it selects the title block, but I cant re-create this in Autolisp. Any help would be greatly appreciated!
(setq name (cdr (assoc 2 (entget (car (entsel "\nSelect Block for name swap:"))))))
(command "-rename" "block" name "borderd")
This code sets a variable name to whatever the title block name is so that I can run Rename and change the block from what ever it is to something that I can control. The idea of changing it to something that I know is so that I can use Blockreplace.
Welcome to CADTutor. :)
You might want to take a look at one of Lee Mac's fantastic lisps,
as it sounds like it might be helpful in this endeavor.
http://www.lee-mac.com/bfind.html
Thanks Lee! :beer:
