Place text from Notepad as per origin point given in notepad (Delimitted with ;)
Sample.txtHi
I need a lisp to place text as per given data in notepad. Innotepad Coordinates and Text is delimited with Semicolon (;) symbol. Need toread from notepad and place text as per Coordinate.
Thanks in Advance.
You may build by yourself a script from that file; use Excel to speed-up the process.
_TEXT [color=magenta]0,0[/color] 5.0 0.0 [color=magenta]NAME1[/color]
_TEXT [color=magenta]1,1[/color] 5.0 0.0 [color=magenta]NAME2[/color]
_TEXT [color=magenta]2,2[/color] 5.0 0.0 [color=magenta]NAME3[/color]
_TEXT [color=magenta]3,3[/color] 5.0 0.0 [color=magenta]NAME4[/color]
<end of script>
Thanks for Quick reply.
Actually i need a lisp. I am reading datafrom another software and save in notepad using Delimiter. based on this inputs from notepad lisp automatically need to place text.
Here is the codes that I did post in the SWAMP .
(defun c:Test (/ f o Deconstruct_String cm st l)
 (if (and (setq f (getfiled "Select Txt file " "" "txt" 16))
          (setq o (open f "r"))
     (defun Deconstruct_String (st delimiter / p l)
       ;;    Tharwat 01. Nov. 2012     ;;
       (while (setq p (vl-string-search delimiter st 0))
         (setq l  (cons (substr st 1 p) l)
               st (substr st (+ p 2) (strlen st))
       (if st
         (setq l (cons st l))
       (setq l (reverse l))
     (setq cm (getvar 'CMDECHO))
     (setvar 'CMDECHO 0)
     (while (setq st (read-line o))
       (setq l (Deconstruct_String st ";"))
       (if (and l (vl-string-search "," (car l)) (eq (length l) 2))
         (vl-cmdf "_.TEXT" (car l) (getvar 'TEXTSIZE) "0." (cadr l))
     (setvar 'CMDECHO cm)
     (close o)
