Chris Thoms Posted July 22, 2014 Posted July 22, 2014 I have just posted about a specific method of doing what I want in the macro sub-forum, but in considering this problem I have looked into LISP as well for a solution.My intent is to create a button that will allow me to insert a specific block and then scale it and edit its attribute in various ways depending on the cvport and dimscale values. I found a LISP routine here {http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/AutoCAD-Macro-block-inserts-and-layers/td-p/4326319} in my searching for information that seems to be promising: (vl-load-com) (defun c:FOO (/ *error* blockName oldClayer oldOrthomode layerName) (defun *error* (msg) (and oldClayer (setvar 'clayer oldClayer)) (and oldOrthomode (setvar 'orthomode oldOrthomode)) (cond ((not msg)) ; Normal exit ((member msg '("Function cancelled" "quit / exit abort"))) ; <esc> or (quit) ((princ (strcat "\n** Error: " msg " ** "))) ; Fatal error, display it ) (princ) ) (if (findfile (setq blockName "HVLV-UB610x125.dwg")) (progn (setq oldClayer (getvar 'clayer)) (setq oldOrthomode (getvar 'orthomode)) (vla-put-color (vla-add (vla-get-layers (vla-get-activedocument (vlax-get-acad-object) ) ) (setq layerName "E-LIGHTING-CEIL") ) acred ) (setvar 'clayer layerName) (setvar 'orthmode 1) (command "._-insert" blockName pause 1. 1. 0.) ) (prompt (strcat "\n** Block \"" blockName "\" not found ** ")) ) (*error* nil) ) And this is a macro call for it: ^C^C^P(if (not c:FOO)(load "FOO.lsp")) FOO ^P I am kind of learning as I go how things work, but I want to make sure I am not headed down a bad path with this potential solution. Would it be possible to pass the block name, like "2x2_r_n.dwg", to the LISP routine with a macro call? If not, then is there a better way to do this? Actually, regardless... is there a better way to do this? lol I'm perhaps foolishly confident that I can eventually get my macro to work without invoking LISP, but this LISP routine would provide me with more options for the future. Quote
