Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
  1. #11
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    Just in case you didn't read it, this from Wikipedia:
    BIM Software
    Due to the complexity of gathering all the relevant information when working with BIM on a building project some companies have developed software designed specifically to work in a BIM framework. These packages (e.g.: Autodesk Revit, ARCHIBUS EIM with BIM 4.0, ArchiCAD) differ from architectural drafting tools such as AutoCAD and VectorWorks by allowing the addition of further information (time, cost, manufacturers' details, sustainability and maintenance information, etc.) to the building model.
    Drafting is a breeze.
  2. #12
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,139
    Quote Originally Posted by nestly View Post
    The Revit crowd is getting bigger and louder.
    Maybe so, but the AutoCAD crowd is getting smaller and crying louder.
    There's an abundance of "BIM" classes in the Autodesk University archives for AutoCAD vertical products, so clearly someone is redefining "BIM"
    I'll agree that the term "BIM" has been severely exploited. Severely. Let's set aside this acronym for a moment... since there's so many differences in definitions.
    AutoCAD vertical products, at it's core, is a non-collaborative drawing application. Revit, at it's core, is a collaborative database. Neither of these two applications are directly comparable in any way. If this is true, and agreeable, then why would any term (BIM or otherwise) be used to compare them? BIM (or, "insert catchy marketing term here") equals Revit, therefore it does not equal AutoCAD and/or the subsequent vertical products.... and vice versa.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
  3. #13
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    So, you started off by saying to drop the term and follow it up by using it twice. The term has a definition and agreed it is misused, but what is key is the words around it. AutoCAD can be a part if the BIM process but it is not capable of being the process.
    When it comes to a "catchy marketing term", it starts to become meaningless because of the words around it. There is a big difference between, BIM compatible and BIM capable. Many programs can be a part of the process but few can run the process.
  4. #14
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,139
    Quote Originally Posted by RobDraw View Post
    AutoCAD can be a part of the BIM process but it is not capable of being the process.
    That's a really good way to put it actually. Revit "is" the process, and AutoCAD can do nothing more but be part of the process. But that still may be giving AutoCAD too much credit and is misleading, which is why most people do not credit AutoCAD at all.
  1. convert .ipt to .prt and vice versa
    By AfricanDan in forum Autodesk Inventor
    Last Post: 3rd May 2012, 10:33 pm
  2. Converting MS to PS and vice versa
    By Lithium in forum AutoCAD Beginners' Area
    Last Post: 27th Feb 2009, 08:39 pm
  3. ecad to mcad and vice versa
    By larsulph in forum Electrical
    Last Post: 24th Nov 2008, 07:18 pm
  4. Convert .cdr to .dwg or vice versa?
    By todorb2000 in forum AutoCAD Beginners' Area
    Last Post: 29th Sep 2008, 11:12 pm
Tags for this Thread
