Hi guys
I have a routine with name "fl" for modify pline in my drawing and it operate for any pline one by one via selecting user ,,i wanna write a loop for do this routine for all pline in my selection set that automatically select pline and do "fl" until the end .something like this:
(foreach pline in selection set do "fl")
(repeat)
Appreciate for any idea and helping
best regard
How do you propose to build your selection set of pline's. Would you be individually selecting plines to build the set or do you want to apply to all plines in the drawing ?
You also need to post the "fi" code, it is likely that will need some modification as there is likely a "get..." function in there that will not be needed, and the function definition would need to be modified like;
defun c:fi ( x / .........)
You hit it on the head though with the foreach function;
(foreach x plinelist
   (fi x)
Where plinelist is your selection set list of pline's, no need for the repeat as the foreach function is essentially doing that.
This is my routine:
(DEFUN C:fl   () (COMMAND "_FILLET" "p" "7" ))
and i wanna this repeat for all pline in selection set (ssget)
thanxxx
After a little searching I found this code from Tharwat, (although it looks like the header info was previously removed, the poster did give credit to Tharwat though) on another site.
(defun c:Test (/ ss fr)
 (if (setq ss (ssget "_:L" '((0 . "LWPOLYLINE"))))
     (setq fr (getvar 'FILLETRAD))
     (setvar 'FILLETRAD 0)                  ;CHANGE THIS VALUE TO WHATEVER RADIUS YOU DESIRE
     ((lambda (i / sn)
        (while (setq sn (ssname ss (setq i (1+ i))))
          (vl-cmdf "_.fillet" "_Polyline" sn)
       -1
     (setvar 'FILLETRAD fr)
This runs fine, just select all your plines at once when prompted.
Appreciateeeeeeeeeeee so much mate
and is there a way for modify it for adjust linweight and line type of plines and color??? (for example lineweight 0.2 and continues and blue)
Edited by hosyn
Try this;
     ((lambda (i / sn)
                   "_.change" sn "" "Properties" "Color"     "Blue"
                                                 "LWeight"   "0.2"
                                                 "LType"     "continuous" ""
       -1
Have fun.
Soooo thanxxxxxxx Mr Snownut
