I want to create one non-printing object - not all objects in a layer ... how?
Set the dxf 60 to 1 then print after that reset the value to 0 to show back the previous selected objects .
Search the forum and you should find at least two threads as far as I can remember .
A work around will be to store a "no-plot" flag into entities as extended data and redefine the PLOT command to temporary move all entities bearing it into a no-plot layer, proceed to plot and move them back to their original layer.
Is not about visibility... but i think is impossible other way...
If you hide it, will not be printed either, so Tharwat is correct.
Really ?
How far are you sure ?
I'm not sure... I will be happy to be wrong... :)
Try this and let me know who's wrong . :danger:
(defun c:hideobjs (/ ss i sn)
 ;;    Tharwat 30.July.2014        ;;
 ;;    Hide objects temporary        ;;
 (princ "\n Select objects to hide ")
 (if (setq i  -1
           ss (ssget "_:L")
   (while (setq sn (ssname ss (setq i (1+ i))))
     (entmod (append (entget sn) (list (cons 60 1))))
(defun c:showobjs (/ ss i sn)
 ;;    Show hidden objects         ;;
 (if (setq i  -1
           ss (ssget "_X" '((60 . 1)))
     (entmod (append (entget sn) (list (cons 60 0))))
Your lisp is perfect! Sorry for my english, but this is not what i want ... i was thinking about setting an object to be non-printable but still visible... and THIS I think is impossible...
Your lisp is perfect! Sorry for my eglish, but this is not what i want ... i was thinking about setting an object to be non-printable but still visible... ant THIS I think is impossible...
So you should take Mircea's Advise .
Convert plotstyles to .stb, set one style to color 255,255,254 and apply it to each object you don't want to be plotted.
