Draw vertical line
robertbon
Help please! I am trying to write a quick lisp routine to draw a vertical line from a user selected point:
(defun c:lz()
(setq pt1 (getpoint " Pick Point: "))
(setq x (rtos (car pt1)))
(setq y (rtos (cadr pt1)))
(setq pt2 (strcat x "," y ",100"))
(command "line" pt1 pt2 "")
e.g. if I click on point 10,20 it will draw a line from 10,20,0 to 10,20,100.
How do I get the pt2 variable into the line command without it being a string?
Thanks,
Rob
Thanks, 7o7.
That was stage 1 of 2 for what I am trying to achieve:
I have 2 view ports, 1 for plan and 1 for elevation. I draw the vertical line in the plan using lz routine above. I then switch to the elevation vport and I want to change the z value of the line I just created line to 0, relative to the elevation vport.
How can I do this?
Thanks,
Rob
1. Line is drawn vertically from plan
2. I switch to vport in front view.
3. I want to change the z value of the line to 0
(defun c:lz()
(setq SnapVal (getvar "osmode"))
(command "osmode" "0")
(setq pt2 (list (car pt1) (cadr pt1) 100))
(command "osmode" SnapVal)
2 refinements required:
1. If I click on an end point of a line in plan it creates a zero-length line? I added osmode 0 to code but it does not overcome this.
2. Due to rounding precision the lines aren't truly vertical - if I wanted to use @0,0,100 for pt2 instead how would I implement that?
Consider this mod .
(defun c:lz (/ p1 )
 (while (setq p1 (getpoint "\n Pick Point: "))
   (entmake (list '(0 . "LINE")(cons 10 p1) (cons 11 (polar p1 (/ pi 2.) 100.))))
Thanks Tharwat,
I have tried this and a couple of variations but I am still having the same problems as above:
1. If I have snaps on and click on an end point of a line in plan it creates a zero-length line? I added osmode 0 to code after selecting pick point but it does not overcome this.
2. Due to rounding precision the lines aren't truly vertical - (command "line" pt1 "@0,0,100" "") still gives me slightly non-vertical lines, though it works fine when I do it manually in the command line
Can anyone shed some light on this for me? I am drawing lots of elevations based on floor plans and typing @0,0,100 for every vertical line from plan is sending me slowly mad!
Rob
Vertical line relative to UCS:
(defun c:vl1 ( / p )
   (if (setq p (getpoint "\nSpecify point for line: "))
       (entmake
           (list
              '(0 . "LINE")
               (cons 10 (trans p 1 0))
               (cons 11 (trans (mapcar '+ p '(0 100 0)) 1 0))
Vertical line relative to WCS:
(defun c:vl2 ( / p )
       (entmake
           (list
              '(0 . "LINE")
               (cons 11 (mapcar '+ (trans p 1 0) '(0 100 0)))
  • 8 years later...
Hi,
I'm trying to alter Lee's lisp vl1 so that the length of the line can be set on the go.
Its currently defined as 100
This is where I have got to, but I'm not sure what I am doing, its probably not the right way, it errors:
Command: VLE2
Specify point for line: Enter Y Value: 44.51
; error: bad argument type: numberp: V
;;;Vertical line relative to UCS:
(defun c:vle2 ( / p )
		(if (setq v (getreal "\Enter Y Value: "))
       (entmake
           (list
              '(0 . "LINE")
               (cons 11 (trans (mapcar '+ p '(0 v 0)) 1 0))
Pleas can you show me where I'm going wrong?
Thanks
You're almost right. Your error results in the sense that you are using the quoted expression: '(0 v 0). When you quote an expression, everything is interpreted as its face-value, meaning the variable v is not evaluated to what the value is supposed to be and is read as a symbol. That's why the error you're encountering indicates that the symbol V has been passed when a number is to be expected.
To fix it, you will need to open a list. So instead of '(0 v 0), you should write (list 0 v 0) instead, so that v is evaluated to your user input.
  • Like 3
Ah balls.  I thought I had it.
Looks like
(cons 11 (trans (mapcar '+ p (list 0 v 0)) 1 0))
adds the value of 'v' to the existing 'p' coordinates, so it is all relative to 'p', whereas i want 'v' to be an absolute value.
so I need to take 'p' and substitute the Y value for the value of 'v'
(defun c:vlu ( /  )
		(setq v (getreal "\nEnter Y Value: "))
		(setq p2 (list (car p) v (caddr p)))
       (entmake
           (list
              '(0 . "LINE")
               (cons 11 (trans p2 1 0))
Seems to be working..  I removed the if statement as I'm not sure how to make it work for more than one statement.
Looks like
(defun c:vlu ( /  )
       (entmake
           (list
              '(0 . "LINE")
Use the PROGN function to group multiple expressions whilst only returning the last evaluated expression:
(if (setq p2 (getreal ...))
    ;; Everything true here
    ;; Everything false here
In your case, you don't need the false statement.
