Hello guys .
I need to use a reactor to re write the text string as it was inserted with a routine if any user changed this text string .
This is my codes and it doesn't work , can anyone help me please ?
(defun c:write (/ pnt txtobj)
 (vl-load-com)
    (setq pnt (getpoint "\n text location :"))
     (setq txtobj (entmakex (list '(0 . "TEXT")
                             (cons 10 pnt)
                             (cons 11 pnt)
                             (cons 40 1.0)
                             (cons 1 "Text example")
     (setq *obj* (vlr-object-reactor
                   (list (vlax-ename->vla-object txtobj))
                   "example-1"
                   '((:vlr-modified . modifytext))
(defun modifytext (noifier reactor paparms /)
 (vla-put-textstring (vlr-data reactor) "Text example")
What Object Type is reactor, and what does (vlr-data reactor) return?
Your code is not working because (vlr-data reactor) in the case is the string "example-1", it doesn't mean anything.
You have to put another text object as vlr-data, cad don't let you take reactor's owner (as active object) and reactor's data (as passive object) the same object.
You try this:
 (vl-load-com)
                             (cons 10 pnt)
                             (cons 11 pnt)
                             (cons 40 1.0)
    (setq txtobj1 (car (entsel "\nChoose another text:")))
	    (list (vlax-ename->vla-object txtobj1))
(defun modifytext (notifier reactor paparms /)
 (vla-put-textstring (car (vlr-data reactor)) "Text example rewrote")
thank you for reply .
I think vlr-data is the data associated with a reactor . i don't know more .
You try this:
 (vl-load-com)
                             (cons 10 pnt)
                             (cons 11 pnt)
                             (cons 40 1.0)
thank you so much for explanations and modifying codes , very helpful reply many thanks .:thumbsup:
