Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 22
  1. #11
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,743
    Quote Originally Posted by bjenk8100 View Post
    ill double check tomorrow. almost positive there is no object tracking in lite. it has tracking after you start to draw but you cannot drag off something that tracks off of that to start at an exact level. I use a large crosshair but using that to line up to something away from where you are is not exact. Then applying dimensions would not be exact which is maybe one of the first things i learned, draw everything to scale or it will eat you alive later.
    Not having object snap tracking or Polar Tracking is not a LT thing. If it existed for either version in 2005, it is in both full and LT. I have only been using LT since 1995 so I am too young to remember that far back. I'm only 67. To remove any doubt, run the command DSETTINGS to see if you have the Polar Tracking and Object Snap tabs on the dialog. You do have the Object Snaps selected properly and turned on, right? How tracking works depends on which snaps are activated.
    Someone mentioned dynamic input. That was introduced in 2007. (maybe 2006).
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  2. #12
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,743
    yes, that is my exact thinking. I just cant believe that object tracking is not in lite. That just sux. And yes 2005. I learned from 2009-14 but this company uses 2005 lite. Drawings are not super hard but you have to do crap like you mentioned. You cant even trim multiple lines. Thanks for your reply though. I think that probably is the only way. This company has five users. Upgrading to regular autocad would be impossible to convince this old owner.
    Tell your boss that a single seat license for 2015 LT only costs $45.00 per month on subscription and will probably be less per seat for multiples. I figure if he can't afford that, he's doing more wrong than just being cheap on software.
  3. #13
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Just to clear it up. From looking at a screen shot of AutoCAD 2005 LT, there is Polar Tracking and Object Snap but not Object Snap Tracking.
    Drafting is a breeze.
  4. #14
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,588
    Object Tracking was introduced in R14, and not R2014 but R14.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  5. #15
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Quote Originally Posted by rkent View Post
    There is no Object Tracking. It's Polar Tracking that was introduced before 2005. The OP is asking about Object Snap Tracking which is different.
  6. #16
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    Quote Originally Posted by RobDraw View Post
    I'm surprised to learn this, but everything I've found also indicates that LT did not have OSnap Tracking at that time.
    "From" Osnap is still one of my favorites to begin drawing at a known distance from existing geometry.
  7. #17
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,743
    I guess what we are referring to as Object Tracking is actually meant to describe Object Snap tracking because Object Snap Tracking is what I am thinking when I say Object Tracking. Object Tracking as an AutoCad noun does not exist.
    If polar tracking is available in 2005 why can't it work for this as long as the angles of 180 and 90 are in the tracking angles used?
  8. #18
    Super Member
    Dipali's Computer Details
    windows 10
    TOSHIBA "SATELLITE"
    Intel inside CORE i7
    viewsonicVA1916w
    Architectural
    Dipali's Discipline Details
    ARCHITECTURE
    Architectural
    interiors
    AutoCAD 2015
    Dec 2007
    INDIA
    1,106
    BTW, you can trim multiple objects. What exactly are you trying to accomplish? I'm sure there is a way.
    You can use 'F' For fence while trim or any other command is active and you have to select multiple objects in one line. This was present even in 2013 when I started, but it was never listed in options of object selection, so many does not know about it.
    "An architect's most useful tools are an eraser at the drawing board & a wrecking bar at the site."
    Frank Lloyd Wright
  9. #19
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    Mechanical
    Mechanical 2017
    Nov 2007
    4,588
    Object Snap Tracking has been refered to as Object Tracking by many people for a while now so while it may not be an official Autodesk term it is one that has come into general usage by many. A quick search on the web will confirm. Also, I have a book by Ralph Grabowski and in his book he uses Object Tracking to mean Object Snap Tracking.
    I opened AutoCAD 2002 and the OTRACK button is there, so although I am unable to determine when it was introduced I can confirm it was in the program that far back.
  10. #20
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    http://www.hyperpics.com/downloads/r...ence_R2002.pdf
    Verifies it was available in 2002. I cannot verify that it was/was not available in LT.
  1. polar tracking problem
    By jrn in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 9th Nov 2012, 04:15 pm
  2. Polar Tracking not snapping to polar angles
    By dayandow4 in forum AutoCAD General
    Last Post: 4th Nov 2010, 08:56 am
  3. Polar Tracking Backwards
    By skipsophrenic in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 6th Nov 2008, 11:41 am
  4. polar tracking
    By good_m in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Jun 2006, 01:46 pm
  5. Polar Tracking
    By EvilRufusKay in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Nov 2005, 05:29 pm
