ctrl+alt+a for select similar
hi all
i have found some code here to help me reinsert this command, but at present it is like any other lisp command, i.e. entered at the command line.
;;; Select Similar
;;; (based on a command found in a few versions of AutoCAD)
;;; written by Adam Wuellner <mailto:akw@gawab.com>
;;; all rights released
(defun c:selsim  (/ ss1 i ent filter_list type-layer filter sstemp)
 (if (not (setq ss1 (cadr (ssgetfirst))))
   (setq ss1 (ssget)))
 (setq i           0
       filter_list '())
 (repeat (sslength ss1)
   (setq ent (entget (ssname ss1 i))
         i   (1+ i))
   (setq type-layer (list (assoc 0 ent) (assoc 8 ent)))
   (if (not (member type-layer filter_list))
     (setq filter_list (cons type-layer filter_list))))
 (foreach filter  filter_list
   (princ (strcat "selecting all " (cdar filter) " entities on layer " (cdadr filter) "...\n"))
   (setq sstemp (ssget "X" filter))
   (setq ss1    (ss:union ss1 sstemp)
         sstemp nil))
 (sssetfirst nil ss1)
 (princ))
(defun ss:union  (ss1 ss2 / ename ss-smaller ss-larger c)
 (cond ((and ss1 ss2)
        (setq c 0)
        (if (< (sslength ss1) (sslength ss2))
          (setq ss-smaller ss1
                ss-larger ss2)
          (setq ss-larger ss1
                ss-smaller ss2))
        (while (< c (sslength ss-smaller))
          (setq ename (ssname ss-smaller c)
                c     (1+ c))
          (if (not (ssmemb ename ss-larger))
            (ssadd ename ss-larger)))
        ss-larger)
       (ss1 ss1)
       (ss2 ss2)
       (t nil)))
do you know how to change ctrl+shift+a from groups toggle to run this command?
thank you
CUI > Shortcut Keys > Ctrl+Shift+A
Change the macro to:
^c^c(if (not c:selsim)(load"selsim")) selsim;
Make sure "selsim.lsp" is in your support file search path or pre-loaded
thank you - works perfectly
