helpme Posted August 12, 2014 Share Posted August 12, 2014 How can i create a railing in the flooring which is modified using sub elemets like in the attached picture Quote Link to comment Share on other sites More sharing options...
tzframpton Posted August 12, 2014 Share Posted August 12, 2014 Make sure it's hosted. Quote Link to comment Share on other sites More sharing options...
helpme Posted August 12, 2014 Author Share Posted August 12, 2014 I tried but it is not working Quote Link to comment Share on other sites More sharing options...
tzframpton Posted August 12, 2014 Share Posted August 12, 2014 While in sketch mode use the Split Element tool to "segment" the path. Select each segment, and on the Modify Bar, you can adjust each segment individually. The middle segment should be set to "flat" while the others to sloped. Quote Link to comment Share on other sites More sharing options...
rvpas Posted August 16, 2014 Share Posted August 16, 2014 Hi Helpme, Small tutorial about a creation of your railing Good luck ! CADTUTOR-RAILING 081214.zip Quote Link to comment Share on other sites More sharing options...
helpme Posted August 17, 2014 Author Share Posted August 17, 2014 Thank you Rvpas Quote Link to comment Share on other sites More sharing options...
