Hi
multi-select lines , Enter the distance, line at both ends of the lengthen.
Thanks for any help.
Try the attached lisp routine written by ASMI and originally posted here at CADTutor. I'm not sure of the date. The command to type in after loading the routine is blen.
Note: This routine will lengthen or shorten a line at both ends. User's choice.
Test.lsp
Hi
[ATTACH=CONFIG]50379[/ATTACH]
Do you mean both sides?
sub function:
;For Extension of linear (lines & align Dimension only)
;hanhphuc 2014
argument:
_e= ename
ex= extension. 'REAL
id= dxf index. eg: '(10 11)
(defun +exlin (_e ex id / l ep a d)
 (if (and id (= (length id) 2)) ; index list only limited for 2
   (progn (setq l  (entget _e)
	 ep (mapcar ''((x) (cdr (assoc x l))) id)
	 a  (angle (car ep) (cadr ep))
	 d  (apply 'distance ep)
	 ) ;_ end of setq
   (mapcar ''((u v)(entmod [color="blue"] (setq l [/color](subst (cons u v) (assoc u l) l)))) ; <--updated
	   id
	   (mapcar ''((x) (polar (mapcar ''((a b) (/ (+ a b) 2.)) (car ep) (cadr ep)) x (+ (/ d 2.) ex)))
		   (list a (+ a pi))
		   ) ;_ end of mapcar
	   ) ;_ end of mapcar
   ) ;_ end of progn
   ) ;_ end of if
 ) ;_ end of defun
;Example call:
;(+exlin (car(entsel)) 1.0[color="red"] '(10 11)[/color]) <--- click line
;(+exlin (car(entsel)) 1.0[color="red"] '(13 14)[/color]) <--- click aligned dimension
Test:
(if (not *dist*)(setq *dist* 1.0))
(defun c:EXLIN (/ *error* ext e ve os ad)
 (defun *error* (msg)
   (if	(not (wcmatch (strcase msg) "*CANCEL*,*EXIT*"))
     ) ;_ end of if
   ) ;_ end of defun
 (setq	ext (getdist (strcat "\nEnter extension? <" (rtos *dist* 2) "> : "))
os  (getvar "osmode")
) ;_ end of setq
 (if (not ext)
   (setq ext *dist*)
   (setq *dist* ext)
   ) ;_ end of if
 (setvar "osmode" 0)
 (while (and (setq e (entsel "\nPick Aligned Dimension: "))
      (setq ve (vlax-ename->vla-object (car e))
	    ad (vla-get-objectname ve)
	    ) ;_ end of setq
      ) ;_ end of and
   (cond ((apply 'or (mapcar ''(($) (wcmatch ad $)) '("*AcDbAlignedD*" "*AcDbRotatedD*")))
   (+exlin (car e) ext '(13 14))
  ((wcmatch ad "*AcDbLine*") (+exlin (car e) ext '(10 11))) ;(+rdim (car e) ext)
  (t nil)
  ) ;_ end of cond
   ) ;_ end of while
 (setvar "osmode" os)
 ) ;_ end of defun
http://www.cadtutor.net/forum/showthread.php?88181-line-at-both-ends-of-the-extension
(princ "\nhanhphuc 2014. Extension Dimension. Command: EXLIN")
Edited by hanhphuc
My offer with simple thing :)
(defun c:Test (/ ss d i e 1p 2p a)
 ;;    Tharwat 14.Aug.2014        ;;
 (if (and (setq d (getdist "\n Specify distance to add :")) (setq ss (ssget "_:L" '((0 . "LINE")))))
     (setq e  (entget (ssname ss (setq i (1- i))))
           1p (cdr (assoc 10 e))
           2p (cdr (assoc 11 e))
           a  (angle 1p 2p)
     (setq e (subst (cons 10 (polar 2p a d)) (assoc 10 e) e)
           e (subst (cons 11 (polar 1p (+ a pi) d)) (assoc 11 e) e)
     (entmod e)
[ATTACH]50385[/ATTACH]
Thanks Remark , I test your code in Acad2007 , It's OK! can both ends, But I test in Acad2010 , only one end .Puzzled!
           a  (angle 1p 2p)
     (entmod e)
Tharwat , Thanks. Long time no see.
Your routine very good! nice!
Yes, he means both ends.
@hi ReMark thanks , i was confused whether pick line or dimension, then i made both.:)
& Tharwat
mine the dimension has become non-associative, is it normal?
I did not interpret the original post to include the dimension. I think the OP put it there to demonstrate the "before" and "after" line lengths.
The routine I posted, written by ASMI, was tested using AutoCAD 2015 and it worked.
Note that until I posted the first response no one else had offered a solution. Now the OP has more than one. Nice.
Yes ,both sides.
Thanks for your code. It's OK! but why dimension did not follow the lines ? Remark and Tharwat's code can!
Excellent , you are welcome :)
I am daily trolling AutoLISP forums and specially CADTutor ;)
& Tharwat
I think no , your dimensions that associated with the modified lines should be changed according to new changes on lines if they are associated dimensions .
A little modification on the codes to avoid an upside down of dimensions ;)
           a  (angle 1p 2p)
     (setq e (subst (cons 10 (polar 1p (+ a pi) d)) (assoc 10 e) e)
           e (subst (cons 11 (polar 2p a d)) (assoc 11 e) e)
     (entmod e)
Yes, it's normal - you modified dimension, so it now has no valid association entity to take association from...
Yes ,both sides.
i figured out..
inside sub-function
;This was incorrect..
(mapcar ''((u v) [color="red"](setq l[/color] (entmod  (subst (cons u v) (assoc u l) l)))) ....
;should be this
(mapcar ''((u v) (entmod [color="red"](setq l [/color](subst (cons u v) (assoc u l) l)))) ....
Thank you :-)
i figured out..
inside sub-function
;should be this
Thank you :-)
Thanks hanhphuc , It's the same too.
Thank you marko for the info.
for line it should be associative, it's wield why not function by others?
Edited by hanhphuc
  • 2 years later...
Thank you so much guys, that lisp just made my life a lot easier :)
