manohar Posted August 18, 2014 Share Posted August 18, 2014 (edited) Dear Lisp Experts, Currently i am doing planting annotation manually, which involves list area of polyline, multiply the area with density of plants in a sqm, then place leader and text with calculated qty and plant name near the polyline. I don't know how to write lisp, if anyone have spare time, please help me a lisp to do the following: At first instance of command in a drawing , lisp to invoke the user to select drawing unit either M or MM. 1. Select Plant name text exist in the Drawing. 2. Select polyline (Planting area) and list its area (If drawing unit is in MM divide the area by 1,000,000 to convert the area to Sq.m) 3. Ask for Density of Planting 4. Multiply entered density and listed area 5. Round off the Result to nearest full number. 6. Place leader with three points at user picked location and place single line text (with Current Text and Dimension style) with Calculated Qty followed by a space and then Selected plant name. 7. Continue with same name of planting for the other areas untill operation is cancelled. Thanks in advance. Manohar. Edited August 18, 2014 by manohar Spell Check & More Details Added Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 19, 2014 Share Posted August 19, 2014 Sounds like a good task to write your 1st lisp, just read some of the posts in the lisp section for code, we all started at some point hints getstring entsel getreal * entsel getreal fix getpoint getpoint getpoint command leader wrap all above in while Quote Link to comment Share on other sites More sharing options...
manohar Posted August 19, 2014 Author Share Posted August 19, 2014 (edited) Sounds like a good task to write your 1st lisp, just read some of the posts in the lisp section for code, we all started at some point Thanks Bigal for your Motivation and Hints.. This is what i came up with Bigal's hints and most of copy paste from various codes. it is stopped with ; error: bad argument type: numberp: nil reason being not coded correctly and not finished. Please help me. Also code is currently asking to enter the plant name which i want to have either user to enter or select existing text string, but i don't know what to do. (defun c:plabel (/ plantname pldens endata e a b entype newtxt P1 P2 P3 ) ;; store and set system variables (setq osmode (getvar "osmode") cmdecho (getvar "cmdecho") ); setq (and (null unit) ;<-- will only ask you once (not (initget "M MM")) (setq unit (cadr (assoc (getkword "\nChoos units to use [M/MM]: ") '(("M" 1.0)("MM" 0.000001)))))) (setvar "osmode" 0) (setvar "cmdecho" 0) (while (getstring plantname "\nEnter the Plant Name: ") (getstring pldens "\nEnter Density of Planting: ") ;; get polyline from user selection (setq pline (car (entsel "\nSelect Planting Boundary: "))) ;; get the area, do the math (command ".area" "e" pline) (setq area (getvar "area")) (setq b (* area pldens)) (setq a (* b unit)) (setq a (rtos a 2 0)) (setq newtxt (strcat a " " PlantName)) (setvar "cmdecho" 1) (princ NewText) (setvar "cmdecho" 0) (COMMAND "OSNAP" "OFF") (setq p1 (getpoint"\nLeader start point: ")) (setq p2 (getpoint P1"\nLeader Second point: ")) (setq p3 (getpoint P2"\nLeader end point: ")) (COMMAND "LEADER" p1 p2 p3 "") (COMMAND "TEXT" "M" P3 "" newtxt) (princ) ) ) Edited August 19, 2014 by manohar Quote Link to comment Share on other sites More sharing options...
pBe Posted August 19, 2014 Share Posted August 19, 2014 Post a sample drawing of "before" and "after", that way we can give a better suggestions manohar. Quote Link to comment Share on other sites More sharing options...
manohar Posted August 19, 2014 Author Share Posted August 19, 2014 Post a sample drawing of "before" and "after", that way we can give a better suggestions manohar. Please find attached. Text marked in blue color is for explaining my requirement. Red color polyline & texts in the legend are existing. PLABEL.dwg Quote Link to comment Share on other sites More sharing options...
pBe Posted August 19, 2014 Share Posted August 19, 2014 Also code is currently asking to enter the plant name which i want to have either user to enter or select existing text string, but i don't know what to do. SelectionOrText by LM As for the posted code, you can replace these lines... (getstring plantname "\nEnter the Plant Name: ") (getstring pldens "\nEnter Density of Planting: ") with what you would pick up from the link i posted above HTH Quote Link to comment Share on other sites More sharing options...
manohar Posted August 19, 2014 Author Share Posted August 19, 2014 SelectionOrText by LM As for the posted code, you can replace these lines... Thanks.. Still struck at ; error: bad argument type: numberp: nil After solving this i will try LM's sub routine. Quote Link to comment Share on other sites More sharing options...
pBe Posted August 20, 2014 Share Posted August 20, 2014 (edited) hang on... That error is brought about by multiplying the area value with a nil value. On your code pldens is not defined (getstring pldens "\nEnter Density of Planting: ") Should have been (setq pldens (getstring "\nEnter Density of Planting: ")) but then again. value from that will give you a "string" value . use getint or getreal depending on your needs (setq pldens (getreal "\nEnter Density of Planting: ")) Edited August 20, 2014 by pBe Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 20, 2014 Share Posted August 20, 2014 Just some suggestions, Dont use reserved words can cause problems. If you load into VLIDE and Tools Load, under Debug is Last break source should at least show where it stopped. (setq osmode (getvar "osmode") cmdecho (getvar "cmdecho") ) (setq oldsnap (getvar "osmode") oldecho (getvar "cmdecho") ) (setq pline (setq obj (setq area (setq objarea ; suggest use osmode for snaps easier to set to any combo you want just Osnap then type Osmode will see snap settings number ;I group all the current settings at start also back to default last (COMMAND "OSNAP" "OFF") (setvar "osmode" 0) ; mixing reals and strings may cause an error (setq a (rtos a 2 0)) (setq ans (rtos a 2 0)) If you load into VLIDE and Tools Load, under Debug is Last break source should at least show where it stopped. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted August 21, 2014 Share Posted August 21, 2014 Try this and let me know if this serves your needs . (defun c:Plant (/ *error* d id f _strings 1p 2p i sn ss spc r txt) (or doc (setq doc (vla-get-ActiveDocument (vlax-get-acad-object)))) ;; ;; ;; Author : Tharwat Al Shoufi ;; ;; Date: 21. August. 2014 ;; ;; ;; (defun *error* (msg / del) (if (and d (setq d (findfile d))) (vl-file-delete d) ) (if (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*") (princ (strcat "\n ** Error : " msg " **")) ) ) ;; ;; (cond ((and (setq d (vl-filename-mktemp nil nil ".dcl")) (setq f (open d "w"))) (progn (write-line (strcat "test : dialog { label = \"Planting Annotation \"; fixed_height = true; width = 40; fixed_width = true;" ": text { label = \"Author : Tharwat Al Shoufi \" ; alignment = centered;}" "spacer;" ": boxed_column {" ": row { : text {label = \"Text\";} : popup_list { key = \"str\"; width = 20; fixed_width = true;}}" ": row { : text {label = \"Units\";} : edit_box { key = \"unit\"; width = 20; fixed_width = true;}}" ": row { : text { label = \"Density\"; } : edit_box { key = \"den\"; width = 20; fixed_width = true;}}" ": row { : text { label = \"Text Height :\";} : edit_box { key = \"hgt\"; width = 20; fixed_width = true;}}}" "spacer_1;" ": row { : button { label = \"Okay \"; key = \"oki\"; width = 14; is_default = true ;} : button { label = \"Exit\"; key = \"esc\"; width = 14; is_cancel = true ; }}}" ) f ) (close f) ) ) (t (alert "Can't load the temporary file <!>")) ) (if (or (not d) (not (new_dialog "test" (setq id (load_dialog d))))) (progn (if (>= id 0) (unload_dialog id) ) (if (and d (setq d (findfile d))) (vl-file-delete d) ) ) (progn (setq _strings '("SH/CLER.I" "SH/GARD.J" "SH/JASM.S" "SH/CARI.G" "GC/SETC.P" "GC/RUEL.C" "GC/JACQ.C" "H/CLER.I")) (start_list "str") (mapcar 'add_list _strings) (end_list) (if *Planting* (mapcar 'set_tile (list "str" "unit" "den" "hgt") *Planting*) (set_tile "unit" "1000000") ) (action_tile "oki" "(setq *Planting* (mapcar 'get_tile (list \"str\" \"unit\" \"den\" \"hgt\"))) (done_dialog)" ) (action_tile "esc" "(done_dialog)") (start_dialog) (unload_dialog id) (vl-file-delete d) ) ) (if *Planting* (cond ((not (numberp (read (cadr *Planting*)))) (alert "Unit value must be number(s) ONLY !")) ((not (numberp (read (caddr *Planting*)))) (alert "Density value must be number(s) ONLY !")) ((not (numberp (read (nth 3 *Planting*)))) (alert "Text Height must be number(s) ONLY !")) ((and (princ "\n Select Closed objects :") (setq ss (ssget '((0 . "CIRCLE,ELLIPSE,LWPOLYLINE"))))) (setq spc (vlax-get-property doc (if (eq (getvar 'TILEMODE) 1) 'Modelspace 'PaperSpace ) ) ) (vla-startUndomark doc) (repeat (setq i (sslength ss)) (setq sn (vlax-ename->vla-object (ssname ss (setq i (1- i))))) (if (wcmatch (vla-get-objectname sn) "AcDb*line") (progn (setq 1p (vlax-get (setq r (car (vlax-invoke spc 'addregion (list sn)))) 'centroid)) (vla-delete r) ) (setq 1p (vlax-get sn 'center)) ) (setq 2p (polar 1p (* pi 0.25) (* 15. (atof (nth 3 *Planting*))))) (setq txt (vlax-invoke spc 'addmtext (trans 2p 1 0) 0.0 (strcat (rtos (* (/ (vla-get-area sn) (atof (cadr *Planting*))) (atof (caddr *Planting*))) 2 0) " " (nth (atoi (car *Planting*)) _strings) ) ) ) (vla-put-height txt (nth 3 *Planting*)) (vlax-invoke spc 'addleader (append (trans 1p 1 0) (trans 2p 1 0)) txt aclinewitharrow) ) (vla-endundomark doc) ) (t (princ "\n Exit without any action !")) ) ) (princ) )(vl-load-com) Quote Link to comment Share on other sites More sharing options...
pBe Posted August 21, 2014 Share Posted August 21, 2014 Try this and let me know if this serves your needs . (defun c:Plant (.. Thats nice and all tharwat, but we were aiming to let the OP figure it out on his own. At any rate, we hope the OP will learn form your post. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted August 21, 2014 Share Posted August 21, 2014 Thats nice and all tharwat, but we were aiming to let the OP figure it out on his own. At any rate, we hope the OP will learn form your post. Thank you pBe . I hope that I was misunderstood with my codes in your following up thread . The OP PM me to help him , so I wrote it on their demand and nothing's more . Regards. Quote Link to comment Share on other sites More sharing options...
manohar Posted August 21, 2014 Author Share Posted August 21, 2014 (edited) Thank you pBe . I hope that I was misunderstood with my codes in your following up thread . The OP PM me to help him , so I wrote it on their demand and nothing's more . Regards. Thank you Tharwat for responding my PM. I have not tested it. Thanks pBe, it is my first lisp, i dont think i can learn lisp and write of my own during this short time. I will try to learn as early as possible. Edited August 21, 2014 by manohar Quote Link to comment Share on other sites More sharing options...
Tharwat Posted August 21, 2014 Share Posted August 21, 2014 Thank you Tharwat for responding my PM. I have not tested it. You're welcome , just let me know after you have the time to test the routine . Good luck . Quote Link to comment Share on other sites More sharing options...
manohar Posted August 21, 2014 Author Share Posted August 21, 2014 Awesome, as always from Tharwat. it doesn't get better than this.. Thanks a lot:D:thumbsup: Quote Link to comment Share on other sites More sharing options...
Tharwat Posted August 21, 2014 Share Posted August 21, 2014 Awesome, as always from Tharwat. it doesn't get better than this.. Thanks a lot:D:thumbsup: Waw excellent , you are very welcome and I am glad to help Note: The routine gives the opportunity to select many objects with one shot . * You can add more texts from your LEGEND to the routine and you can recognize that with a little search among the codes ( just ask if you couldn't ) Regards. Quote Link to comment Share on other sites More sharing options...
pBe Posted August 22, 2014 Share Posted August 22, 2014 The OP PM me to help him , so I wrote it on their demand and nothing's more . Since you put it that way then proceed as requested Carry on. Cheers dude. Quote Link to comment Share on other sites More sharing options...
