motee-z Posted August 19, 2014 Posted August 19, 2014 please help how to convert this list (setq a'("1 2.33 6.45 8.46" "2 8.98 4.78 1.58" "3 4.51 7.12 2.35" "4 6.95 5.64 7.82")) to this list (setq a '((1 2.33 6.45 8.46)(2 8.98 4.78 1.58)(3 4.51 7.12 2.35)(4 6.95 5.64 7.82))) Quote
7o7 Posted August 20, 2014 Posted August 20, 2014 (edited) You use this: (mapcar '(lambda(x) (read (strcat "(" x ")"))) a) Edited August 20, 2014 by SLW210 Code Tags Quote
Tharwat Posted August 20, 2014 Posted August 20, 2014 Another . (defun 2->list (l) (if l (setq l (cons (read (strcat "(" (car l) ")")) (2->list (cdr l))))) ) Quote
7o7 Posted August 20, 2014 Posted August 20, 2014 (edited) You are welcome motee-z. @Tharwat : Thanks for the alternative, but in this case I think using mapcar is easier to understand than recursive. Edited August 20, 2014 by 7o7 Quote
Tharwat Posted August 20, 2014 Posted August 20, 2014 @Tharwat : Thanks for the alternative, but in this case I think using mapcar is easier to understand than recursive. I do agree with you . Quote
Lee Mac Posted August 21, 2014 Posted August 21, 2014 (defun 2->list (l) (if l (setq l (cons (read (strcat "(" (car l) ")")) (2->list (cdr l))))) ) Note that there is no need for the setq expression to redefine the variable 'l' - The list will be constructed and returned as a consequence of the cons expression being the last expression evaluated. Quote
Tharwat Posted August 21, 2014 Posted August 21, 2014 Note that there is no need for the setq expression to redefine the variable 'l' - The list will be constructed and returned as a consequence of the cons expression being the last expression evaluated. You are right , thank you Lee for taking the time to correct me . Quote
hanhphuc Posted August 22, 2014 Posted August 22, 2014 You use this: (mapcar '(lambda(x) (read (strcat "(" x ")"))) a) 7o7. i noted your idea as good tips, thanks i didn't notice it was string list by OP, luckily gurus are always here Tharwat alternative idea & Lee simple yet useful advise. Thank you guys Quote
7o7 Posted August 22, 2014 Posted August 22, 2014 7o7. i noted your idea as good tips, thanks i didn't notice it was string list by OP, luckily gurus are always here Tharwat alternative idea & Lee simple yet useful advise. Thank you guys You are guru too, my friend Quote
