+ Reply to Thread
Results 1 to 5 of 5
  1. #1
    Forum Newbie
    Using
    LDD 2009
    Join Date
    Aug 2014
    Posts
    3
    Default Fatal Error on LDD 2009
    I'm new at the forum and have to get a drawing out the door. I am a surveyor. Here's what I have, It just started. When I go to import points, then click the folder for the destination of the .txt or ascii file it gives me a fatal error. Never had this happen. I did open up another drawing someone set me that was pretty old but I did have any problems with it. Also, it remember the last destination folder and I tried to import it and it had no problem. So I put that folder on the jump drive to see if it would give me a fatal error and didn't, just couldn't find it, but when I click the folder icon(destination folder for .txt) I get a fatal error every time. Any Ideas????
    Thank you.
  2. #2
    Forum Newbie
    Using
    MDT 2009
    Join Date
    Aug 2014
    Location
    Miami, FL
    Posts
    6
    Default
    I am having the same issue in LDC2009 Win7 64bit but the Vertical Alignment Editor does NOT open. Anyone have any idea of this problem?
  3. #3
    Forum Newbie
    Using
    LDD 2009
    Join Date
    Aug 2014
    Posts
    3
    Default Fatal Error
    stevendrew12, I went in and changed the point settings and it worked. If you need to know my point setting, I can email them to you. Greg.
    Also, do you or anyone else know how to get the dialog boxes back up. For example, when I do a "save as" I get moved to the command line like I'm back in Dos or something. Happens now with a lot of commands that are in my toolbar. This all started happening when I downloaded the Free TrueView from AutoCAD to convert newer drawings to older versions. Thanks. Greg.
  4. #4
    Computer Details
    SLW210's Computer Details
    Operating System:
    Windows 7 PRO 64-bit
    Computer:
    IBM Lenovo
    Motherboard:
    ACPI x64
    CPU:
    Pentium(R) i5 4570 @ 3.2GHz
    RAM:
    8 GB RAM
    Graphics:
    Nvidia Quadro 600 1GB
    Primary Storage:
    300 GB
    Secondary Storage:
    650GB
    Monitor:
    2x ThinkVision 24"
    Discipline
    Multi-disciplinary
    SLW210's Discipline Details
    Occupation
    Design Draftsman
    Discipline
    Multi-disciplinary
    Details
    Using
    AutoCAD 2018
    Join Date
    May 2007
    Location
    South Florida, USA
    Posts
    12,128
    Default
    Check the Value of FILEDIA
    FILEDIA
    See Also
    Switch Between Dialog Boxes and the Command Line
    Type: Integer
    Saved in: Registry
    Initial value: 1
    Suppresses display of file navigation dialog boxes.
    0 Does not display dialog boxes. You can still request a file dialog box to appear by entering a tilde (~) in response to the command's prompt. The same is true for AutoLISP and ADS functions.
    1 Displays dialog boxes. However, if a script or AutoLISP/ObjectARX™ program is active, an ordinary prompt is displayed.
    And CMDDIA
    CMDDIA
    See Also
    Create and Modify Leaders
    Type: Integer
    Saved in: Registry
    Initial value: 1
    Controls the display of the In-Place Text Editor for the LEADER and QLEADER commands.
    0 Off
    1 On
    also ATTDIA
    ATTDIA
    See Also
    Insert Blocks
    Type: Integer
    Saved in: Registry
    Initial value: 0
    Controls whether the INSERT command uses a dialog box for attribute value entry.
    0 Issues Command prompts
    1 Uses a dialog box
  5. #5
    Forum Newbie
    Using
    LDD 2009
    Join Date
    Aug 2014
    Posts
    3
    Default Thanks
    Thanks so much. I am getting dialog boxes now. Do you know any good resources for learning IntelliCAD? My computer crashed and I am having to learn Carlson 2015 with IntelliCAD. I am coming from LDD2009. Thanks.
Similar Threads
  1. fatal error unhandled access violation writing Error prb
    By bercha85 in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 17th Jan 2011, 03:34 pm
  2. 2010 Error - FATAL ERROR: Unhandled e0434f4dh Exception at 770f76fdh
    By ezdanny in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 1st Sep 2010, 04:53 pm
  3. revit 2009 fatal error prompt
    By darris07 in forum Revit General
    Last Post: 3rd Dec 2008, 05:09 pm
  4. AutoCAD 2009 fatal error when trying to use DIMSTYLE
    By Mark R in forum AutoCAD General
    Last Post: 11th Sep 2008, 03:53 pm
  5. AutoCAD 2009 Fatal Error!!!
    By Lucy3609 in forum AutoCAD General
    Last Post: 28th May 2008, 04:45 pm
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
