adrath Posted August 26, 2014 Share Posted August 26, 2014 Hi all, I have a corridor set up, with custom subassemblies using shape codes to calculate materials like pavement, concrete, base and subbase. I cut quantity sample lines along all of the base lines and used a materials list to produce dynamic volume tables in the drawing for both cut/fill (earthworks) and all of the materials mentioned above. All of this works great. What I need is to create a PDF report for all of the materials. The Volume Report tool works for the cut/fill quantities, but when I try to produce a materials report, all of the cells just reflect a quantity of 0.00. With the Volume Report tool, there doesn't seem to be a way to specify the material within the material list so I'm guessing that that tool is meant for cut/fill volumes only. Anyone know how to produce material volume reports short of using the plot command to plot each of the tables in the drawing to PDF? Quote Link to comment Share on other sites More sharing options...
