souvik Posted September 1, 2014 Posted September 1, 2014 Hi all. I have two polylines which have same length. One polyline contain some intersection at random distance. I need to mark the other polyline with the same intersection distance.. Quote
marko_ribar Posted September 1, 2014 Posted September 1, 2014 Hi all. I have two polylines which have same length. One polyline contain some intersection at random distance. I need to mark the other polyline with the same intersection distance.. What exactly do you mean with "One polyline contain some intersection" - do you think ab vertices... Please clarify... Quote
souvik Posted September 1, 2014 Author Posted September 1, 2014 Please have a look to the attachment Sample.dwg Quote
hanhphuc Posted September 1, 2014 Posted September 1, 2014 http://www.lee-mac.com/intersectionfunctions.html HTH Quote
marko_ribar Posted September 1, 2014 Posted September 1, 2014 Here try this : (defun c:mark_intersections_of_1st_curve_on_2nd ( / unique g3 c1 c2 ss i ent p pl d dl pn pnl ) (vl-load-com) (defun unique ( l ) (if l (cons (car l) (unique (vl-remove (car l) (cdr l)))))) (defun g3 ( l ) (if l (cons (list (car l) (cadr l) (caddr l)) (g3 (cdddr l))))) (setq c1 (car (entsel "\nPick first curve that has intersections"))) (while (vl-catch-all-error-p (vl-catch-all-apply 'vlax-curve-getstartparam (list c1))) (prompt "\nPicked entity don't belong to curves... Try again...") (setq c1 (car (entsel "\nPick first curve that has intersections"))) ) (setq ss (ssget "_X")) (setq c2 (car (entsel "\nPick second curve that should be marked with intersections of first curve"))) (while (vl-catch-all-error-p (vl-catch-all-apply 'vlax-curve-getstartparam (list c2))) (prompt "\nPicked entity don't belong to curves... Try again...") (setq c2 (car (entsel "\nPick second curve that should be marked with intersections of first curve"))) ) (setq i -1) (while (setq ent (ssname ss (setq i (1+ i)))) (if (vl-catch-all-error-p (vl-catch-all-apply 'vlax-curve-getstartparam (list ent))) (ssdel ent ss) ) ) (ssdel c1 ss) (ssdel c2 ss) (setq i -1) (while (setq ent (ssname ss (setq i (1+ i)))) (if (setq p (vlax-invoke (vlax-ename->vla-object c1) 'intersectwith (vlax-ename->vla-object ent) acextendnone)) (foreach p (g3 p) (setq pl (cons p pl)) ) ) ) (setq pl (unique pl)) (foreach p pl (setq d (vlax-curve-getdistatpoint c1 p)) (setq dl (cons d dl)) ) (foreach d dl (setq pn (vlax-curve-getpointatdist c2 d)) (setq pnl (cons pn pnl)) ) (foreach pn pnl (entmake (list '(0 . "POINT") (cons 10 pn))) ) (if (not (member (vlax-curve-getstartpoint c2) pnl)) (entmake (list '(0 . "POINT") (cons 10 (vlax-curve-getstartpoint c2)))) ) (if (not (member (vlax-curve-getendpoint c2) pnl)) (entmake (list '(0 . "POINT") (cons 10 (vlax-curve-getendpoint c2)))) ) (princ) ) (defun c:mi1st2nd nil (c:mark_intersections_of_1st_curve_on_2nd)) HTH, M.R. Quote
souvik Posted September 1, 2014 Author Posted September 1, 2014 Thanks for the program But I'm getting this error: ---------- error: bad function: vlax-curve-getStartParam I'm using Autocad 2010... Quote
marko_ribar Posted September 1, 2014 Posted September 1, 2014 It's written that you're using A2012... Have you tested the code on 2012... On my netbook with A2008 it works fine... Currently I am on a vacation and I can't replicate your error... Note that I included line (vl-load-com) which enables vlisp extensions among which is also (vlax-curve-getstartparam)... Does someone have the same error when tested above posted code? Please if so reply... I just can't figure out what was the problem... Quote
