PaddlesUpRiver Posted September 2, 2014 Share Posted September 2, 2014 How do I get the line style of my pipe networks to stop matching the line style of the current layer I am working on? This has been happening ever since I switched to AutoCAD Civil 3D 2014. In a nutshell: My storm pipe networks are always drawn in solid white lines. However, if I do some editing on another layer in the drawing -- say existing gas which looks like -------- GAS ------- GAS ------- GAS -------, then the lines for my pipe network will look and print as existing gas. If I change to a waterline layer, then my pipe network will look and print like the waterline layer. Also, the change seems to be superficial -- the line style as it is listed in the properties of the pipe network still shows as a solid white line even though it doesn't look not print as a solid white line while another layer is the current layer. How can I make this stop before I go bezerk! PaddlesUpRiver Quote Link to comment Share on other sites More sharing options...
RobDraw Posted September 3, 2014 Share Posted September 3, 2014 I've never seen that before. A couple of things to try/look at: Have you restarted? Is this only in one file, some files, or all files? Quote Link to comment Share on other sites More sharing options...
PaddlesUpRiver Posted September 3, 2014 Author Share Posted September 3, 2014 Yes, I've tried restarting. And it happens in all my files -- including new files. Quote Link to comment Share on other sites More sharing options...
