afrazawan Posted September 10, 2014 Share Posted September 10, 2014 i have one layout need to show Barrier in this layout so each barrier size 4 metr and gape b/w 2cm so kindly how can I make or divide equal If i make barrier blok 4X0.60 metr so I need to copy paste it is difficult any such other way to make layout showing barriers Quote Link to comment Share on other sites More sharing options...
MSasu Posted September 10, 2014 Share Posted September 10, 2014 If the said barrier block is to be placed along an existing entity (i.e. a polyline) then may worth looking for MEASURE command. Quote Link to comment Share on other sites More sharing options...
afrazawan Posted September 10, 2014 Author Share Posted September 10, 2014 plz see the attachments bellow and you can see outer road edge I need to show / proposed barrier 4 x 0.60 with 0.02 meter spacing Drawing2.dwg Quote Link to comment Share on other sites More sharing options...
steven-g Posted September 10, 2014 Share Posted September 10, 2014 Your easiest option would be the measure command, draw a center line for the barrier, and select this line for the measure command, it then gives the option to use a block (look at the command line) with a distance of 4.02m and aligned with the polyline. Then delete the line, you could use an edge line but then you need to change the block insertion point to suit. Barrier.dwg Quote Link to comment Share on other sites More sharing options...
afrazawan Posted September 10, 2014 Author Share Posted September 10, 2014 Your easiest option would be the measure command, draw a center line for the barrier, and select this line for the measure command, it then gives the option to use a block (look at the command line) with a distance of 4.02m and aligned with the polyline. Then delete the line, you could use an edge line but then you need to change the block insertion point to suit. but how can set his edge on equal align,thanks for above help Quote Link to comment Share on other sites More sharing options...
steven-g Posted September 10, 2014 Share Posted September 10, 2014 In the attached I have changed the block so the insertion point is at the centre of one edge, so it will align correctly to the edge of a polyline. Barrier.dwg Quote Link to comment Share on other sites More sharing options...
afrazawan Posted September 10, 2014 Author Share Posted September 10, 2014 i need to align one by one block plz little more help? Quote Link to comment Share on other sites More sharing options...
steven-g Posted September 10, 2014 Share Posted September 10, 2014 Why one by one Quote Link to comment Share on other sites More sharing options...
afrazawan Posted September 10, 2014 Author Share Posted September 10, 2014 can you inbox me ur social media account for live chat? Quote Link to comment Share on other sites More sharing options...
