motee-z Posted September 10, 2014 Posted September 10, 2014 any idea how to get text height when i picked single line text Quote
Tharwat Posted September 10, 2014 Posted September 10, 2014 Hi. Try this . (if (setq s (ssget "_+.:S" '((0 . "TEXT,MTEXT")))) (setq hgt (cdr (assoc 40 (entget (ssname s 0))))) ) Quote
motee-z Posted September 10, 2014 Author Posted September 10, 2014 hello tharwat thanks for reply can we extract text height from this selection method (setq 1pt(entget (car (entsel "\nSelect text: ")))) Quote
Tharwat Posted September 10, 2014 Posted September 10, 2014 can we extract text height from this selection method (setq 1pt(entget (car (entsel "\nSelect text: ")))) Sure , but you have to be sure that the user selected a text and not any other object Anyway here it goes . (setq hgt (cdr (assoc 40 1pt))) Quote
motee-z Posted September 10, 2014 Author Posted September 10, 2014 thank you tharwat for your kindness Quote
Tharwat Posted September 10, 2014 Posted September 10, 2014 thank you tharwat for your kindness You are welcome anytime . Have a read of THIS which consist of all related DXF codes for the single line text Quote
BIGAL Posted September 11, 2014 Posted September 11, 2014 (edited) VL example same thing no test for if text (setq obj (vlax-ename->vla-object(car (entsel "\nSelect text: ")))) (vla-get-textstring obj) ; text entered (vla-get-height obj) ; height of text (vla-get-rotation obj) ; text angle ; to mention a few if you want more download Dumpit.lsp this will produce list ; or (entget (car (entsel))) ; this will show dxf code numbers like 40 above Edited September 12, 2014 by BIGAL Quote
Tharwat Posted September 11, 2014 Posted September 11, 2014 BIGAL , the OP is asking for text height and not for text string Quote
