Hi, someone I know has put one of my menus in there AutoCAD 2008 version.
The toolbars show up, but not the menu. All the toolbars function correctly.
What could be the issue?
Thanks
is it a POP menu or a Ribbon menu. Also if using the Ribbon you must turn on Menu bar, Top left little down arrow.
It's a POP menu. Was the ribbon even in 2008? I didn't think it was.
Sounds like an error in the menu is it a partial MNU file or have you added it in some way via the CUI command. It does not take much for a MNU to not work. If ok post a copy here
Ok, here it is in code. I actually installed a version of AutoCAD 2008 myself to test it out. At first it worked, but after I uninstalled it, it wouldn't show on the menu bar again, even using the CUI rather than just menuload command.
***MENUGROUP=SMC-Melbourne
***POP25
[sMC-Melbourne]
[->Shadow Generate...]
   [->June 22nd]
ID_juneAll    [All Hours]^c^c(load "Shadow Multi Cast Melb.vlx");_shadowJune;
ID_june9123    [9am 12pm 3pm]^c^c(load "Shadow Multi Cast Melb.vlx");_shadow-9-12-3-June;
ID_juneMS    [Morning Shadows]^c^c(load "Shadow Multi Cast Melb.vlx");_shadow-morningJune;
ID_juneAS    [Afternoon Shadows]^c^c(load "Shadow Multi Cast Melb.vlx");_shadow-afternoonJune;
       [->Single Hour]
   ID_8AM            [ 8am]^c^c(load "Shadow Multi Cast Melb.vlx");_SingleHourJune8am;\\^c^c^c^c^c^c
   ID_9AM            [ 9am]^c^c(load "Shadow Multi Cast Melb.vlx");_SingleHourJune9am;\\^c^c^c^c^c^c
   ID_10AM            [10am]^c^c(load "Shadow Multi Cast Melb.vlx");_SingleHourJune10am;\\^c^c^c^c^c^c
   ID_11AM            [11am]^c^c(load "Shadow Multi Cast Melb.vlx");_SingleHourJune11am;\\^c^c^c^c^c^c
   ID_12pM            [12pm]^c^c(load "Shadow Multi Cast Melb.vlx");_SingleHourJune12pm;\\^c^c^c^c^c^c
   ID_1pM            [ 1pm]^c^c(load "Shadow Multi Cast Melb.vlx");_SingleHourJune1pm;\\^c^c^c^c^c^c
   ID_2pM            [ 2pm]^c^c(load "Shadow Multi Cast Melb.vlx");_SingleHourJune2pm;\\^c^c^c^c^c^c
   ID_3pM            [ 3pm]^c^c(load "Shadow Multi Cast Melb.vlx");_SingleHourJune3pm;\\^c^c^c^c^c^c
   ID_4pM            [<-<- 4pm]^c^c(load "Shadow Multi Cast Melb");_SingleHourJune4pm;\\^c^c^c^c^c^c
ID_sept    [->September 22nd]
ID_septALL    [All Hours]^c^c(load "Shadow Multi Cast Melb.vlx");_shadowSept;
ID_sept9123    [9am 12pm 3pm]^c^c(load "Shadow Multi Cast Melb.vlx");_shadow-9-12-3-Sept;\\^c^c^c^c^c^c
ID_septMS    [Morning Shadows]^c^c(load "Shadow Multi Cast Melb.vlx");_shadow-morningSept;\\^c^c^c^c^c^c
ID_septAS    [Afternoon Shadows]^c^c(load "Shadow Multi Cast Melb.vlx");_shadow-afternoonSept;\\^c^c^c^c^c^c
       [->Single Hour]
   ID_7AM            [ 7am]^c^c(load "Shadow Multi Cast Melb.vlx");_SingleHourSept7am;\\^c^c^c^c^c^c
   ID_8AM            [ 8am]^c^c(load "Shadow Multi Cast Melb.vlx");_SingleHourSept8am;\\^c^c^c^c^c^c
   ID_9AM            [ 9am]^c^c(load "Shadow Multi Cast Melb.vlx");_SingleHourSept9am;\\^c^c^c^c^c^c
   ID_10AM            [10am]^c^c(load "Shadow Multi Cast Melb.vlx");_SingleHourSept10am;\\^c^c^c^c^c^c
   ID_11AM            [11am]^c^c(load "Shadow Multi Cast Melb.vlx");_SingleHourSept11am;\\^c^c^c^c^c^c
   ID_12pM            [12pm]^c^c(load "Shadow Multi Cast Melb.vlx");_SingleHourSept12pm;\\^c^c^c^c^c^c
   ID_1pM            [ 1pm]^c^c(load "Shadow Multi Cast Melb.vlx");_SingleHourSept1pm;\\^c^c^c^c^c^c
   ID_2pM            [ 2pm]^c^c(load "Shadow Multi Cast Melb.vlx");_SingleHourSept2pm;\\^c^c^c^c^c^c
   ID_3pM            [ 3pm]^c^c(load "Shadow Multi Cast Melb.vlx");_SingleHourSept3pm;\\^c^c^c^c^c^c
   ID_4pM            [ 4pm]^c^c(load "Shadow Multi Cast Melb.vlx");_SingleHourSept4pm;\\^c^c^c^c^c^c
   ID_5pM            [<-<- 5pm]^c^c(load "Shadow Multi Cast Melb.vlx");_SingleHourSept5pm;\\^c^c^c^c^c^c
ID_dec    [->December 22nd]
ID_DECall    [All Hours]^c^c(load "Shadow Multi Cast Melb.vlx");_shadowDec;
ID_Dec9123    [9am 12pm 3pm]^c^c(load "Shadow Multi Cast Melb.vlx");_shadow-9-12-3-Dec;\\^c^c^c^c^c^c
ID_DECMS    [Morning Shadows]^c^c(load "Shadow Multi Cast Melb.vlx");_shadow-morningDec;\\^c^c^c^c^c^c
ID_DECAS    [Afternoon Shadows]^c^c(load "Shadow Multi Cast Melb.vlx");_shadow-afternoonDec;\\^c^c^c^c^c^c
       [->Single Hour]
   ID_7AM            [ 7am]^c^c(load "Shadow Multi Cast Melb.vlx");_SingleHourDec7am;\\^c^c^c^c^c^c
   ID_8AM            [ 8am]^c^c(load "Shadow Multi Cast Melb.vlx");_SingleHourDec8am;\\^c^c^c^c^c^c
   ID_9AM            [ 9am]^c^c(load "Shadow Multi Cast Melb.vlx");_SingleHourDec9am;\\^c^c^c^c^c^c
   ID_10AM            [10am]^c^c(load "Shadow Multi Cast Melb.vlx");_SingleHourDec10am;\\^c^c^c^c^c^c
   ID_11AM            [11am]^c^c(load "Shadow Multi Cast Melb.vlx");_SingleHourDec11am;\\^c^c^c^c^c^c
   ID_12pM            [12pm]^c^c(load "Shadow Multi Cast Melb.vlx");_SingleHourDec12pm;\\^c^c^c^c^c^c
   ID_1pM            [ 1pm]^c^c(load "Shadow Multi Cast Melb.vlx");_SingleHourDec1pm;\\^c^c^c^c^c^c
   ID_2pM            [ 2pm]^c^c(load "Shadow Multi Cast Melb.vlx");_SingleHourDec2pm;\\^c^c^c^c^c^c
   ID_3pM            [ 3pm]^c^c(load "Shadow Multi Cast Melb.vlx");_SingleHourDec3pm;\\^c^c^c^c^c^c
   ID_4pM            [ 4pm]^c^c(load "Shadow Multi Cast Melb.vlx");_SingleHourDec4pm;\\^c^c^c^c^c^c
   ID_5pM            [<-<- 5pm]^c^c(load "Shadow Multi Cast Melb.vlx");_SingleHourDec5pm;\\^c^c^c^c^c^c
   [->June / Sept / Dec]
ID_ALL        [All Hours]^c^c(load "Shadow Multi Cast Melb.vlx");_shadow-All;\\^c^c^c^c^c^c
ID_all9123    [9am 12pm 3pm]^c^c(load "Shadow Multi Cast Melb.vlx");_shadow-9-12-3-All;\\^c^c^c^c^c^c
ID_allMS    [Morning Shadows]^c^c(load "Shadow Multi Cast Melb.vlx");_shadow-morningAll;\\^c^c^c^c^c^c
ID_allAS    [<-<-Afternoon Shadows]^c^c(load "Shadow Multi Cast Melb.vlx");_shadow-afternoonAll;\\^c^c^c^c^c^c
[->Show Shadows for...]
   [->June 22nd]
ID_j8amSSF    [ 8am June]^c^c(load "Shadow Multi Cast Melb.vlx");_8amJune;
ID_j9amSSF    [ 9am June]^c^c(load "Shadow Multi Cast Melb.vlx");_9amJune;
ID_j10amSSF    [10am June]^c^c(load "Shadow Multi Cast Melb.vlx");_10amJune;
ID_j11amSSF    [11am June]^c^c(load "Shadow Multi Cast Melb.vlx");_11amJune;
ID_j12pmSSF    [12pm June]^c^c(load "Shadow Multi Cast Melb.vlx");_12pmJune;
ID_j1pmSSF    [ 1pm June]^c^c(load "Shadow Multi Cast Melb.vlx");_1pmJune;
ID_j2pmSSF    [ 2pm June]^c^c(load "Shadow Multi Cast Melb.vlx");_2pmJune;
ID_j3pmSSF    [ 3pm June]^c^c(load "Shadow Multi Cast Melb.vlx");_3pmJune;
ID_j4pmSSF    [ 4pm June]^c^c(load "Shadow Multi Cast Melb.vlx");_4pmJune;
ID_j9123SSF    [9am 12pm 3pm]^c^c(load "Shadow Multi Cast Melb.vlx");_9-12-3-June;
ID_j811amSSF    [8am - 11am]^c^c(load "Shadow Multi Cast Melb.vlx");_8-11-June;
ID_j124pmSSF    [12pm - 4pm]^c^c(load "Shadow Multi Cast Melb.vlx");_12-4-June;
ID_joNSFF    [show All June]^c^c(load "Shadow Multi Cast Melb.vlx");_allJune;
ID_jOffSFF        [<-Hide All June]^c^c(load "Shadow Multi Cast Melb.vlx");_alloffjune;
   [->September 22nd]
ID_s7amSSF    [ 7am September]^c^c(load "Shadow Multi Cast Melb.vlx");_7amSept;
ID_s8amSSF    [ 8am September]^c^c(load "Shadow Multi Cast Melb.vlx");_8amSept;
ID_s9amSSF    [ 9am September]^c^c(load "Shadow Multi Cast Melb.vlx");_9amSept;
ID_s10amSSF    [10am September]^c^c(load "Shadow Multi Cast Melb.vlx");_10amSept;
ID_s11amSSF    [11am September]^c^c(load "Shadow Multi Cast Melb.vlx");_11amSept;
ID_s12pmSSF    [12pm September]^c^c(load "Shadow Multi Cast Melb.vlx");_12pmSept;
ID_s1pmSSF    [ 1pm September]^c^c(load "Shadow Multi Cast Melb.vlx");_1pmSept;
ID_s2pmSSF    [ 2pm September]^c^c(load "Shadow Multi Cast Melb.vlx");_2pmSept;
ID_s3pmSSF    [ 3pm September]^c^c(load "Shadow Multi Cast Melb.vlx");_3pmSept;
ID_s4pmSSF    [ 4pm September]^c^c(load "Shadow Multi Cast Melb.vlx");_4pmSept;
ID_s5pmSSF    [ 5pm September]^c^c(load "Shadow Multi Cast Melb.vlx");_5pmSept;
ID_s9123SSF    [9am 12pm 3pm]^c^c(load "Shadow Multi Cast Melb.vlx");_9-12-3-Sept;
ID_s811amSSF    [7am - 11am]^c^c(load "Shadow Multi Cast Melb.vlx");_7-11-Sept;
ID_s124pmSSF    [12pm - 5pm]^c^c(load "Shadow Multi Cast Melb.vlx");_12-5-Sept;
ID_soNSFF    [show All Sept]^c^c(load "Shadow Multi Cast Melb.vlx");_allSept;
ID_sOffSFF    [<-Hide All Sept]^c^c(load "Shadow Multi Cast Melb.vlx");_alloffsept;
   [->December 22nd]
ID_d7amSSF    [ 7am December]^c^c(load "Shadow Multi Cast Melb.vlx");_7amDec;
ID_d8amSSF    [ 8am December]^c^c(load "Shadow Multi Cast Melb.vlx");_8amDec;
ID_d9amSSF    [ 9am December]^c^c(load "Shadow Multi Cast Melb.vlx");_9amDec;
ID_d10amSSF    [10am December]^c^c(load "Shadow Multi Cast Melb.vlx");_10amDec;
ID_d11amSSF    [11am December]^c^c(load "Shadow Multi Cast Melb.vlx");_11amDec;
ID_d12pmSSF    [12pm December]^c^c(load "Shadow Multi Cast Melb.vlx");_12pmDec;
ID_d1pmSSF    [ 1pm December]^c^c(load "Shadow Multi Cast Melb.vlx");_1pmDec;
ID_d2pmSSF    [ 2pm December]^c^c(load "Shadow Multi Cast Melb.vlx");_2pmDec;
ID_d3pmSSF    [ 3pm December]^c^c(load "Shadow Multi Cast Melb.vlx");_3pmDec;
ID_d4pmSSF    [ 4pm December]^c^c(load "Shadow Multi Cast Melb.vlx");_4pmDec;
ID_d5pmSSF    [ 5pm December]^c^c(load "Shadow Multi Cast Melb.vlx");_5pmDec;
ID_d9123SSF    [9am 12pm 3pm]^c^c(load "Shadow Multi Cast Melb.vlx");_9-12-3-Dec;
ID_d811amSSF    [7am - 11am]^c^c(load "Shadow Multi Cast Melb.vlx");_7-11-Dec;
ID_d124pmSSF    [12pm - 5pm]^c^c(load "Shadow Multi Cast Melb.vlx");_12-5-Dec;
ID_doNSFF    [show All Dec]^c^c(load "Shadow Multi Cast Melb.vlx");_allDec;
ID_dOffSFF    [<-Hide All Dec]^c^c(load "Shadow Multi Cast Melb.vlx");_alloffDec;
ID_7amSSF        [ 7am]^c^c(load "Shadow Multi Cast Melb.vlx");_7amAll;(alert "Note : There is no Shadow for June 7am");
ID_8amSSF        [ 8am]^c^c(load "Shadow Multi Cast Melb.vlx");_8amAll;
ID_9amSSF        [ 9am]^c^c(load "Shadow Multi Cast Melb.vlx");_9amAll;
ID_10amSSF        [10am]^c^c(load "Shadow Multi Cast Melb.vlx");_10amAll;
ID_11amSSF        [11am]^c^c(load "Shadow Multi Cast Melb.vlx");_11amAll;
ID_12pmSSF        [12pm]^c^c(load "Shadow Multi Cast Melb.vlx");_12pmAll;
ID_1pmSSF        [ 1pm]^c^c(load "Shadow Multi Cast Melb.vlx");_1pmAll;
ID_2pmSSF        [ 2pm]^c^c(load "Shadow Multi Cast Melb.vlx");_2pmAll;
ID_3pmSSF        [ 3pm]^c^c(load "Shadow Multi Cast Melb.vlx");_3pmAll;
ID_4pmSSF        [ 4pm]^c^c(load "Shadow Multi Cast Melb.vlx");_4pmAll;
ID_5pmSSF        [ 5pm]^c^c(load "Shadow Multi Cast Melb.vlx");_5pmAll;(alert "Note : There is no Shadow for June 5pm");
ID_9123SSF    [9am 12pm 3pm]^c^c(load "Shadow Multi Cast Melb.vlx");_9-12-3-All;
ID_811amSSF    [7am - 11am]^c^c(load "Shadow Multi Cast Melb.vlx");_7-11-All;(alert "Note : There is no Shadow for June 7am");
ID_124pmSSF    [12pm - 5pm]^c^c(load "Shadow Multi Cast Melb.vlx");_12-5-All;(alert "Note : There is no Shadow for June 5pm");
ID_oNSFF    [show All Layers]^c^c(load "Shadow Multi Cast Melb.vlx");_LayerShowAll;(alert "Note : There is no Shadow for June 7am or 5pm");
ID_OffSFF    [<-<-Hide All Layers]^c^c_LayerHideAll;
[->Load Viewport State...]
   [->June 22nd]
ID_vp8j        [ 8am June]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VP8amJune;
ID_vp9j        [ 9am June]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VP9amJune;
ID_vp10j        [10am June]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VP10amJune;
ID_vp11j        [11am June]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VP11amJune;
ID_vp12j        [12pm June]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VP12pmJune;
ID_vp1pj        [ 1pm June]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VP1pmJune;
ID_vp2pj        [ 2pm June]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VP2pmJune;
ID_vp3pj        [ 3pm June]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VP3pmJune;
ID_vp4pj        [ 4pm June]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VP4pmJune;
ID_vp9123j        [9am 12pm 3pm]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VP9-12-3-June;
ID_vp811j        [8am - 11am]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VP9-12-3-June;
ID_vp124j        [12pm - 4pm]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VP9-12-3-June;
ID_vpallj        [<-Thaw All June]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VPallJune;
   [->September 22nd]
ID_vp7s        [ 7am September]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VP7amSept;
ID_vp8s        [ 8am September]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VP8amSept;
ID_vp9s        [ 9am September]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VP9amSept;
ID_vp10s    [10am September]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VP10amSept;
ID_vp11s    [11am September]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VP11amSept;
ID_vp12s    [12pm September]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VP12pmSept;
ID_vp1ps    [ 1pm September]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VP1pmSept;
ID_vp2ps    [ 2pm September]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VP2pmSept;
ID_vp3ps    [ 3pm September]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VP3pmSept;
ID_vp4ps    [ 4pm September]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VP4pmSept;
ID_vp5ps    [ 5pm September]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VP5pmSept;
ID_vp9123s    [9am 12pm 3pm]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VP9-12-3-Sept;
ID_vp711s    [7am - 11am]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VP7-11-Sept;
ID_vp125s    [12pm - 5pm]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VP12-5-Sept;
ID_vpalls        [<-Thaw All Sept]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VPallSept;
   [->December 22nd]
ID_vp7d        [ 7am December]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VP7amDec;
ID_vp8d        [ 8am December]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VP8amDec;
ID_vp9d        [ 9am December]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VP9amDec;
ID_vp10d    [10am December]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VP10amDec;
ID_vp11d    [11am December]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VP11amDec;
ID_vp12d    [12pm December]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VP12pmDec;
ID_vp1pd    [ 1pm December]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VP1pmDec;
ID_vp2pd    [ 2pm December]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VP2pmDec;
ID_vp3pd    [ 3pm December]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VP3pmDec;
ID_vp4pd    [ 4pm December]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VP4pmDec;
ID_vp5pd    [ 5pm December]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;;VP5pmDec;
ID_vp9123d        [9am 12pm 3pm]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VP9-12-3-Dec;
ID_vp711d        [7am - 11am]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VP7-11-Dec;
ID_vp125d        [12pm - 5pm]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VP12-5-Dec;
ID_vpalld        [<-<-Thaw All Dec]^c^c(load "Shadow Multi Cast Melb.vlx");_tilemode;0;VPallDec;
[->Rotate Screen]
ID_clock90   [90º Clockwise]^c^cucs;z;90;plan;;
ID_clock90a  [90º Counter-Clockwise]^c^cucs;z;-90;plan;;
ID_180       [180º]^c^cucs;z;180;plan;;
ID_freeucs   [Free UCS]^c^c(load "Shadow Multi Cast Melb.vlx");_freeucs;
[->Save UCS]
ID_sou    [Original UCS]^c^c(load "Shadow Multi Cast Melb.vlx");_sou;
ID_snu    [<-New UCS]^c^c(load "Shadow Multi Cast Melb.vlx");_snu;
[->Restore UCS]
ID_rou    [Original UCS]^c^c(load "Shadow Multi Cast Melb.vlx");_rou;
ID_rnu    [<-<-New UCS]^c^c(load "Shadow Multi Cast Melb.vlx");_rnu;
[->Layer Defaults]
   [->Layer Colours]
ID_JUNECOLOUR    [June Layers]^c^c(load "Shadow Multi Cast Melb.vlx");_updatej;
ID_SEPTCOLOUR    [september Layers]^c^c(load "Shadow Multi Cast Melb.vlx");_updates;
ID_DECCOLOUR    [<-December Layers]^c^c(load "Shadow Multi Cast Melb.vlx");_updated;
   [->Layer Names]
ID_JUNELAYER        [June]^c^c(load "Shadow Multi Cast Melb.vlx");_updatejl;
ID_SEPTLAYER        [september]^c^c(load "Shadow Multi Cast Melb.vlx");_updatesl;
ID_DECLAYER        [<-<-December]^c^c(load "Shadow Multi Cast Melb.vlx");_updatedl;
[->Contact]
ID_home    [<-SMC Online]^c^c(load "Shadow Multi Cast Melb.vlx");SmcHome;
       [->Select Location]
           [->VIC ]
               [Melbourne]^c^c(load "SMC-Location.VLX");loc-melb;
               [Warrnambool]^c^c(load "SMC-Location.VLX");loc-warn;
               [bairnsdale]^c^c(load "SMC-Location.VLX");loc-bairn;
               [<-Mildura]^c^c(load "SMC-Location.VLX");loc-mild;
           [->NSW ]
               [sydney]^c^c(load "SMC-Location.VLX");loc-syd;
               [batemans Bay]^c^c(load "SMC-Location.VLX");loc-bbay;
               [Pt Macquarie]^c^c(load "SMC-Location.VLX");loc-pmac;
               [<-Tweed Heads]^c^c(load "SMC-Location.VLX");loc-thead;
           [->ACT ]
               [<-Canberra]^c^c(load "SMC-Location.VLX");loc-canb;
           [->QLD ]
               [brisbane]^c^c(load "SMC-Location.VLX");loc-bris;
               [bundaberg]^c^c(load "SMC-Location.VLX");loc-bund;
               [Rockhampton]^c^c(load "SMC-Location.VLX");loc-rhamp;
               [Mackay]^c^c(load "SMC-Location.VLX");loc-mack;
               [Townsville]^c^c(load "SMC-Location.VLX");loc-town;
               [<-Cairns]^c^c(load "SMC-Location.VLX");loc-cairns;
           [->NT ]
               [Darwin]^c^c(load "SMC-Location.VLX");loc-darw;
               [<-Alice Springs]^c^c(load "SMC-Location.VLX");loc-asp;
           [->WA ]
               [Perth]^c^c(load "SMC-Location.VLX");loc-perth;
               [Albany]^c^c(load "SMC-Location.VLX");loc-alb;
               [Pt Hedland]^c^c(load "SMC-Location.VLX");loc-pthed;
               [<-Broome]^c^c(load "SMC-Location.VLX");loc-broome;
           [->SA ]
               [Adelaide]^c^c(load "SMC-Location.VLX");loc-adel;
               [Mt Gambier]^c^c(load "SMC-Location.VLX");loc-mtgam;
               [<-Whyalla]^c^c(load "SMC-Location.VLX");loc-why;
           [->TAS ]
               [Hobart]^c^c(load "SMC-Location.VLX");loc-hob;
               [<-<-Launceston]^c^c(load "SMC-Location.VLX");loc-laun;
ID_about    [About]^c^c(load "Shadow Multi Cast Melb.vlx");_SMC-AboutMelb;
       [Help]^c^c(load "SMC-Help");_SMChelp;
       [setup]^c^c(load "c:/Program Files/Shadow Multi Cast/SMC-setup.vlx");SMC-setup;
ID_rm       [Remove Menu]^C^C(load "c:/Program Files/Shadow Multi Cast/SMCrm-Melbourne.vlx");SMCrm-Melbourne;
***TOOLBARS
**Rotate
ID_1 [_Toolbar("Rotate", _Floating, _Show, 202, 151, 1)]
ID_2 [_Button("90° Clockwise", "clockwise", "Clockwise")]^c^cucs;z;90;plan;;
ID_3 [_Button("90° CounterClockwise", "CClockwise", "CClockwise")]^c^cucs;z;-90;plan;;
ID_4 [_Button("180°", "HALFWAY", "HALFWAY")]^c^cucs;z;180;plan;;
ID_5 [_Button("Free UCS°", "FreeUCS", "FreeUCS")]^c^c(load "Shadow Multi Cast Melb.vlx");freeucs;
ID_6 [_Button("All June", "AllJune", "AllJune")]^c^c(load "Shadow Multi Cast Melb.vlx");_shadowJune;
ID_7 [_Button("All September", "AllSept", "AllSept")]^c^c(load "Shadow Multi Cast Melb.vlx");_shadowSept;
ID_8 [_Button("All December", "AllDec", "AllDec")]^c^c(load "Shadow Multi Cast Melb.vlx");_shadowDec;
***HELPSTRINGSs
ID_juneALL  [Generates All shadow lines for the hours 8am - 4pm June 22nd]
ID_june9123 [Generates only shadow lines for the hours 9am 12pm & 3pm June 22nd]
ID_junems   [Generates only shadow lines for the morning hours 8am - 11am June 22nd]
ID_juneas   [Generates only shadow lines for the afternoon hours 12pm - 4pm June 22nd]
ID_septALL  [Generates All shadow lines for the hours 7am - 5pm September 22nd]
ID_sept9123 [Generates only shadow lines for the hours 9am 12pm & 3pm September 22nd (STANDARD selection)]
ID_septms   [Generates only shadow lines for the morning hours 7am - 11am September 22nd]
ID_septas   [Generates only shadow lines for the afternoon hours 12pm - 5pm September 22nd]
ID_decALL  [Generates All shadow lines for the hours 7am - 5pm December 22nd]
ID_dec9123 [Generates only shadow lines for the hours 9am 12pm & 3pm December 22nd]
ID_decms   [Generates only shadow lines for the morning hours 7am - 11am December 22nd]
ID_decas   [Generates only shadow lines for the afternoon hours 12pm - 5pm December 22nd]
ID_ALL  [Generates All shadow lines for the hours 7am - 5pm June / September / December 22nd]
ID_all9123 [Generates only shadow lines for the hours 9am 12pm & 3pm June / September / December 22nd]
ID_allms   [Generates only shadow lines for the morning hours 7am - 11am June / September / December 22nd]
ID_allas   [Generates only shadow lines for the afternoon hours 12pm - 5pm June / September / December 22nd]
ID_7AM       [Generate Shadow for Only 7am]
ID_8AM       [Generate Shadow for Only 8am]
ID_9AM       [Generate Shadow for Only 9am]
ID_10AM       [Generate Shadow for Only 10am]
ID_11AM       [Generate Shadow for Only 11am]
ID_12PM       [Generate Shadow for Only 12pm]
ID_1PM       [Generate Shadow for Only 1pm]
ID_2PM       [Generate Shadow for Only 2pm]
ID_3PM       [Generate Shadow for Only 3pm]
ID_4PM       [Generate Shadow for Only 4pm]
ID_5PM       [Generate Shadow for Only 5pm]
ID_j8amSSF    [Freezes all layers except for 8am June shadow layer]
ID_j9amSSF    [Freezes all layers except for 9am June shadow layer]
ID_j10amSSF    [Freezes all layers except for 10am June shadow layer]
ID_j11amSSF    [Freezes all layers except for 11am June shadow layer]
ID_j12pmSSF    [Freezes all layers except for 12am June shadow layer]
ID_j1pmSSF    [Freezes all layers except for 1pm June shadow layer]
ID_j2pmSSF    [Freezes all layers except for 2pm June shadow layer]
ID_j3pmSSF    [Freezes all layers except for 3pm June shadow layer]
ID_j4pmSSF    [Freezes all layers except for 4pm June shadow layer]
ID_j9123SSF    [Freezes all layers except for 9am 12pm 3pm June shadow layers]
ID_j811amSSF    [Freezes all layers except for 8am - 11am June shadow layers]
ID_j124pmSSF    [Freezes all layers except for 12pm - 4pm June shadow layers]
ID_joNSFF    [Thaws all June layers]
ID_jOffSFF    [Freezes all June layers]
ID_s7amSSF    [Freezes all layers except for 7am September shadow layer]
ID_s8amSSF    [Freezes all layers except for 8am September shadow layer]
ID_s9amSSF    [Freezes all layers except for 9am September shadow layer]
ID_s10amSSF    [Freezes all layers except for 10am September shadow layer]
ID_s11amSSF    [Freezes all layers except for 11am September shadow layer]
ID_s12pmSSF    [Freezes all layers except for 12am September shadow layer]
ID_s1pmSSF    [Freezes all layers except for 1pm September shadow layer]
ID_s2pmSSF    [Freezes all layers except for 2pm September shadow layer]
ID_s3pmSSF    [Freezes all layers except for 3pm September shadow layer]
ID_s4pmSSF    [Freezes all layers except for 4pm September shadow layer]
ID_s5pmSSF    [Freezes all layers except for 5pm September shadow layer]
ID_s9123SSF    [Freezes all layers except for 9am 12pm 3pm September shadow layers]
ID_s811amSSF    [Freezes all layers except for 7am - 11am September shadow layers]
ID_s124pmSSF    [Freezes all layers except for 12pm - 5pm September shadow layers]
ID_soNSFF    [Thaws all September layers]
ID_sOffSFF    [Freezes all September layers]
ID_d7amSSF    [Freezes all layers except for 7am December shadow layer]
ID_d8amSSF    [Freezes all layers except for 8am December shadow layer]
ID_d9amSSF    [Freezes all layers except for 9am December shadow layer]
ID_d10amSSF    [Freezes all layers except for 10am December shadow layer]
ID_d11amSSF    [Freezes all layers except for 11am December shadow layer]
ID_d12pmSSF    [Freezes all layers except for 12am December shadow layer]
ID_d1pmSSF    [Freezes all layers except for 1pm December shadow layer]
ID_d2pmSSF    [Freezes all layers except for 2pm December shadow layer]
ID_d3pmSSF    [Freezes all layers except for 3pm December shadow layer]
ID_d4pmSSF    [Freezes all layers except for 4pm December shadow layer]
ID_d5pmSSF    [Freezes all layers except for 5pm December shadow layer]
ID_d9123SSF    [Freezes all layers except for 9am 12pm 3pm December shadow layers]
ID_d811amSSF    [Freezes all layers except for 8am - 11am December shadow layers]
ID_d124pmSSF    [Freezes all layers except for 12pm - 5pm December shadow layers]
ID_doNSFF    [Thaws all December layers]
ID_dOffSFF    [Freezes all December layers]
ID_7amSSF    [Freezes all layers except for 7am shadow layers]
ID_8amSSF    [Freezes all layers except for 8am shadow layers]
ID_9amSSF    [Freezes all layers except for 9am shadow layers]
ID_10amSSF    [Freezes all layers except for 10am shadow layers]
ID_11amSSF    [Freezes all layers except for 11am shadow layers]
ID_12pmSSF    [Freezes all layers except for 12am shadow layers]
ID_1pmSSF    [Freezes all layers except for 1pm shadow layers]
ID_2pmSSF    [Freezes all layers except for 2pm shadow layers]
ID_3pmSSF    [Freezes all layers except for 3pm shadow layers]
ID_4pmSSF    [Freezes all layers except for 4pm shadow layers]
ID_5pmSSF    [Freezes all layers except for 5pm shadow layers]
ID_9123SSF    [Freezes all layers except for 9am 12pm 3pm shadow layers]
ID_811amSSF    [Freezes all layers except for 7am - 11am shadow layers]
ID_124pmSSF    [Freezes all layers except for 12pm - 5pm shadow layers]
ID_oNSFF    [Thaws all layers]
ID_OffSFF    [Freezes all layers]
ID_vp8j        [Freeze all layers in current viewport except for 8am June shadow layer]
ID_vp9j        [Freeze all layers in current viewport except for 9am June shadow layer]
ID_vp10j    [Freeze all layers in current viewport except for 10am June shadow layer]
ID_vp11j    [Freeze all layers in current viewport except for 11am June shadow layer]
ID_vp12j    [Freeze all layers in current viewport except for 12pm June shadow layer]
ID_vp1pj    [Freeze all layers in current viewport except for 1pm June shadow layer]
ID_vp2pj    [Freeze all layers in current viewport except for 2pm June shadow layer]
ID_vp3pj    [Freeze all layers in current viewport except for 3pm June shadow layer]
ID_vp4pj    [Freeze all layers in current viewport except for 4pm June shadow layer]
ID_vp9123j    [Freeze all layers in current viewport except for 9am 12pm 3pm June shadow layers]
ID_vp811j    [Freeze all layers in current viewport except for 8am - 11am June shadow layers]
ID_vp124j    [Freeze all layers in current viewport except for 12pm - 4pm June shadow layers]
ID_vpallj    [Thaw all June layers in current viewport]
ID_vp7s        [Freeze all layers in current viewport except for 7am September shadow layer]
ID_vp8s        [Freeze all layers in current viewport except for 8am September shadow layer]
ID_vp9s        [Freeze all layers in current viewport except for 9am September shadow layer]
ID_vp10s    [Freeze all layers in current viewport except for 10am September shadow layer]
ID_vp11s    [Freeze all layers in current viewport except for 11am September shadow layer]
ID_vp12s    [Freeze all layers in current viewport except for 12pm September shadow layer]
ID_vp1ps    [Freeze all layers in current viewport except for 1pm September shadow layer]
ID_vp2ps    [Freeze all layers in current viewport except for 2pm September shadow layer]
ID_vp3ps    [Freeze all layers in current viewport except for 3pm September shadow layer]
ID_vp4ps    [Freeze all layers in current viewport except for 4pm September shadow layer]
ID_vp5ps    [Freeze all layers in current viewport except for 5pm September shadow layer]
ID_vp9123s    [Freeze all layers in current viewport except for 9am 12pm 3pm June shadow layers]
ID_vp711s    [Freeze all layers in current viewport except for 7am - 11am September shadow layers]
ID_vp125s    [Freeze all layers in current viewport except for 12pm - 5pm September shadow layers]
ID_vpalls    [Thaw all September layers in current viewport]
ID_vp7d        [Freeze all layers in current viewport except for 7am December shadow layer]
ID_vp8d        [Freeze all layers in current viewport except for 8am December shadow layer]
ID_vp9d        [Freeze all layers in current viewport except for 9am December shadow layer]
ID_vp10d    [Freeze all layers in current viewport except for 10am December shadow layer]
ID_vp11d    [Freeze all layers in current viewport except for 11am December shadow layer]
ID_vp12d    [Freeze all layers in current viewport except for 12pm December shadow layer]
ID_vp1pd    [Freeze all layers in current viewport except for 1pm December shadow layer]
ID_vp2pd    [Freeze all layers in current viewport except for 2pm December shadow layer]
ID_vp3pd    [Freeze all layers in current viewport except for 3pm December shadow layer]
ID_vp4pd    [Freeze all layers in current viewport except for 4pm December shadow layer]
ID_vp5pd    [Freeze all layers in current viewport except for 5pm December shadow layer]
ID_vp9123d    [Freeze all layers in current viewport except for 9am 12pm 3pm June shadow layers]
ID_vp711d    [Freeze all layers in current viewport except for 7am - 11am December shadow layers]
ID_vp125d    [Freeze all layers in current viewport except for 12pm - 5pm December shadow layers]
ID_vpalld    [Thaw all December layers in current viewport]
ID_sou       [saves the current screen rotation]
ID_snu       [saves the new screen rotation]
ID_rou       [Restores the original screen rotation]
ID_rnu       [Restores the new screen rotation]
ID_clock90 [Rotates screen 90° clockwise]
ID_clock90a [Rotates screen 90° counter-clockwise]
ID_180    [Rotates screen 180°]
ID_freeucs [Rotates screen by user input selection]
ID_JUNECOLOUR [Changes the Default layer colour for June Layers]
ID_SEPTCOLOUR [Changes the Default layer colour for September Layers]
ID_DECCOLOUR  [Changes the Default layer colour for December Layers]
ID_JUNELAYER [Changes the Default layer names for June Layers]
ID_SEPTLAYER [Changes the Default layer names for September Layers]
ID_DECLAYER  [Changes the Default layer names for December Layers]
ID_Home        [Opens the Shadow Multi Cast Website]
ID_about    [Displays information about this version of Shadow Multi Cast]
ID_rm        [Removes the Shadow Multi Cast Menu from the Menu Bar]
You know what, forget the code. I think it's a glitch in 2008. The menu now appears, all I did was change workspaces and it appeared. Yay. Now just have to try it on this other persons computer to see if that works too.
Ok when loading menu's it stores in current workspace BUT !!!! if you dont force a save of the current workspace next time you start Autocad it may not be there. The default setting is Do not save we have it set that way so the guys can not stuff it up exiting cad normally fixes their problems.
