muck Posted September 16, 2014 Share Posted September 16, 2014 Is there a VB.net routine to change attributes in an individual drawing block that is selected. I have looked at routines the change the block reference attributes but that changes all drawing blocks in a drawing. Thank you, Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 17, 2014 Share Posted September 17, 2014 This is a VBA example of picking a block with 1 attribute Attribs(0) may be useful Function Getpitname(Newpitname As String) As String Dim PitNameSelect As AcadObject Dim pitattribs As Variant ThisDrawing.Utility.GetEntity PitNameSelect, basepnt, "pick pit name : " If PitNameSelect.ObjectName = "AcDbText" Then Getpitname = PitNameSelect.TextString End If If PitNameSelect.ObjectName = "AcDbBlockReference" Then pitblname = PitNameSelect.Name ' RETURNS BLOCK NAME pitattribs = PitNameSelect.GetAttributes Getpitname = pitattribs(0).TextString End If End Function Quote Link to comment Share on other sites More sharing options...
