Have anyone tried to create a command which draws a polyline according to coordinates of points and the radius of bending? It means that the command draws, for example, a polyline like in attachment, arguments are points marked on yellow and diameter of arch (for example), alternatively there could be also a commend closing polyline.
I have read about the way of counting a radius according to "bulge". I am not sure how I should start - what should be counted into a radius?
I would be very grateful for any help or comments.
Well, if you have all dimensions set, then correct array of dimensions is required in order to get correct array of points - future vertices, and for arced segments I suggest that you use fillet command - it's also required correct array of selected dimensions... But all in all, I would draw that pline manually faster than with possible quirkiness ab obtain correct arrays from sel. sets...
In case of Rs are equal for Pline we can entmake Pline (attached) then use fillit command
(setq obj (entlast))
(command "fillet" "P" "r" 30 obj)
Entmake Min Codes CAB.LSP
try this
(defun c:test ()
 (entmake '((0 . "LWPOLYLINE")
        (100 . "AcDbEntity")
        (8 . "0")
        (100 . "AcDbPolyline")
        (90 . ;Number of vertices
        (10 176.0636632716071 279.6390112374238); 10 =Vertex coordinates (in OCS), multiple entries; one entry for each vertex
        (10 346.0636632716071 279.6390112374238)
        (42 . 0.414213562373095); 42=Bulge (multiple entries; one entry for each vertex) (optional; default = 0)
        (10 376.0636632716071 309.6390112374238)
        (10 376.0636632716071 449.6390112374237)
        (42 . -0.414213562373095)
        (10 406.0636632716071 479.6390112374238)
        (10 568.0354241512509 479.6390112374238)
        (42 . 0.131490546050545)
        (10 583.0188770098191 483.6487026506627)
        (10 821.2389076067196 620.9829165365836)
        (70 . 0);Polyline flag (bit-coded); default is 0: 1 = Closed;
HTH
m.badran
A slight variation on above the point list could come from somewhere else execl etc.
(defun make_sq ()
(setq vertexList (list
(list -3.25 -3.25 0.)
(list 3.25 -3.25 0.)
(list 3.25 3.25 0.)
(list -3.25 3.25 0.)
(entmakex
(append
(list '(0 . "LWPOLYLINE")
'(100 . "AcDbEntity")
'(100 . "AcDbPolyline")
(cons 90 (length vertexList))
(cons 70 1)  ; 1 closed : 0 open
(cons 8 "0")
(cons 38 0.0)
(cons 210 (list 0.0 0.0 1.0))
(mapcar '(lambda (pt) (cons 10 pt)) vertexList)
