BIGAL Posted September 19, 2014 Share Posted September 19, 2014 I can not get this to work I want to pick a txt file tried all sorts of BIT settings it just does not go to the correct directory other tests work. Checked Alpha upper lower etc exactly as it appears in windows. (setq dwgname (GETVAR "dwgname")) (setq dwgname (substr dwgname 1 (vl-string-search ".dwg" dwgname))) (setq dwgname (strcat (getvar "dwgprefix") dwgname "-DATA" "\\" "advRoads-10")) ; dwgname "P:\\2010026\\Design\\2010026-PF-DATA\\AdvRoads-10" (setq fname (getfiled "Select the set out file" dwgname "txt" 4)) Quote Link to comment Share on other sites More sharing options...
7o7 Posted September 19, 2014 Share Posted September 19, 2014 So your file name must be : "P:\\2010026\\Design\\2010026-PF.dwg" and the directory "P:\\2010026\\Design\\2010026-PF-DATA\\AdvRoads-10" must be exist to get the lisp works. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 19, 2014 Author Share Posted September 19, 2014 Thats corrrect I want a sub directory below the current directory level, just can not see typo's. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted September 20, 2014 Share Posted September 20, 2014 Assuming the filepaths exist, try: (setq fname (getfiled "Select the set out file" (strcat (getvar 'dwgprefix) (vl-filename-base (getvar 'dwgname)) "-DATA\\advRoads-10") "txt" 16 ) ) Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 20, 2014 Author Share Posted September 20, 2014 (edited) Thanks Lee will try tomorrow the flag setting may be the key. I did see the vl-filename-base this is better as it removes the .dwg. Yes that worked Lee will have a close look at fname between the two versions to figure out difference. Thanks Edited September 22, 2014 by BIGAL Quote Link to comment Share on other sites More sharing options...
