danielk Posted September 22, 2014 Share Posted September 22, 2014 i have one file who shows all the attributes in model space although they were invisble when i created them , i tried to play with ATTMODE and with BATTMAN and with it works only if find each block and make their attributes "invisible" inside the dialog box. *its a 3d model . and it makes everything work slower. how do i turn off the visibility of all attributes in this file ? Thanks ! Quote Link to comment Share on other sites More sharing options...
RobDraw Posted September 22, 2014 Share Posted September 22, 2014 Did you ATTSYNC after making changes? Quote Link to comment Share on other sites More sharing options...
danielk Posted September 29, 2014 Author Share Posted September 29, 2014 i did attsync ... not a good solution beacuse it should be done seperatley to each block . Quote Link to comment Share on other sites More sharing options...
RobDraw Posted September 29, 2014 Share Posted September 29, 2014 Well then one way or the other you're going to have to do it separately. ATTSYNC does not allow you to pick and choose which blocks to sync. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted September 29, 2014 Share Posted September 29, 2014 ATTDISP Off Quote Link to comment Share on other sites More sharing options...
RobDraw Posted September 29, 2014 Share Posted September 29, 2014 Okay, I totally misread that question. I could not imagine why one would not want any attributes to display. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted September 29, 2014 Share Posted September 29, 2014 ...*its a 3d model . and it makes everything work slower. They can always be turned back On (or Normal). Quote Link to comment Share on other sites More sharing options...
danielk Posted October 1, 2014 Author Share Posted October 1, 2014 ATTDISP Off solved! thank you so much Quote Link to comment Share on other sites More sharing options...
