noobpro70 Posted September 26, 2014 Share Posted September 26, 2014 May I know how to split my drawing into 2 ? Example as below image... Thank ... Quote Link to comment Share on other sites More sharing options...
Tyke Posted September 26, 2014 Share Posted September 26, 2014 Work on your model as just one object in model space and in paper space have two overlapping layouts in which you view just one part of your model. I would not recommend splitting your model into two parts. Quote Link to comment Share on other sites More sharing options...
sparkyuk Posted September 26, 2014 Share Posted September 26, 2014 (edited) Make a view port in paper space and set the scale that allows you to see the drawing ether left or right side and then make another Layout and do the same for the other side, I always make a small view port as the Layout on the left as the sample you added, just has showing what part of the building you are seeing in the view port, hope that helps Edited September 26, 2014 by sparkyuk Changed the word Drawing to Layout as Dana noted below Quote Link to comment Share on other sites More sharing options...
Dana W Posted September 26, 2014 Share Posted September 26, 2014 make a view port in paper space and set the scale that allows you to see the drawing ether left or right side and them make another drawing and do the same for the other side, I always make a small view port as the drawing on the left as the sample you added, just has showing what part of the building you are seeing in the view port, hope that helpsI would replace the word Drawing, with the word Layout in this statement. There already is a language issue. Don't mean to be jumping on your case, just helping, maybe. Quote Link to comment Share on other sites More sharing options...
