hamidciv Posted September 26, 2014 Posted September 26, 2014 hi dear friends :(pleae help me for problem in easy code: (defun c:test4() (defun getpoly () (command "area" "object" ent) (getvar "perimeter") ) (setq ent (car(entsel))) ) Quote
mostafa badran Posted September 26, 2014 Posted September 26, 2014 (defun c:test4 () (setq ent (car (entsel))) (command "area" "object" ent) (getvar "perimeter") ) Quote
hamidciv Posted September 26, 2014 Author Posted September 26, 2014 dear mostafa I mean this was not, i want define multiple function in one code and use them, similar to JefferyPSanders writen for addlength, Something like this: (defun c:test4 () ; ;;;--- Function to get the length of an ARC entity (defun getArc(en) (command "lengthen" en "") (getvar "perimeter") ) ;;;--- Function to get the length of a LINE entity (defun getLine(en) (setq enlist(entget en)) (distance (cdr(assoc 10 enlist)) (cdr(assoc 11 enlist))) ) ;;;--- Function to get the length of a POLY, CIRCLE, SPLINE, OR ELLIPSE (defun getPoly(en) (command "area" "Object" en) (getvar "perimeter") ) . . . . . ) Quote
mostafa badran Posted September 26, 2014 Posted September 26, 2014 maybe this help. [color=red](getPoly (car (entsel)))[/color] (defun getPoly(en) (command "area" "Object" en) (getvar "perimeter") ) Quote
marko_ribar Posted September 27, 2014 Posted September 27, 2014 mostafa, red line must be the last one... Order of loading functions is also important... M.R. Quote
hamidciv Posted September 27, 2014 Author Posted September 27, 2014 (edited) :)thanks dear mostafa & marko my problem is solved. Edited September 27, 2014 by hamidciv Quote
asos2000 Posted September 27, 2014 Posted September 27, 2014 Read this http://www.theswamp.org/index.php?topic=13046.msg158557#msg158557 Hoping gives an answer Quote
asos2000 Posted September 27, 2014 Posted September 27, 2014 thanks asos for help me. You are most welcome Quote
mostafa badran Posted September 27, 2014 Posted September 27, 2014 Oops thanks marko you right. the defun must be loaded firstly. mostafa, red line must be the last one... Order of loading functions is also important... M.R. Quote
BIGAL Posted September 28, 2014 Posted September 28, 2014 If you use VL you can Vl-get-area so will work for plines and circles also vl-get-length. Quote
SLW210 Posted September 29, 2014 Posted September 29, 2014 hamidciv, Please read the Code Posting Guidelines and edit your post to include the Code in Code Tags. Quote
