Please can someone explane me about the value , that request when we try to
zoom to center.
And why cant we activate snap on during this option.
Try these which working? red can be modified= magnification/ height
(command "zoom" "c" (getvar "viewctr") [color="red"]10[/color])
(command "zoom" "c" (getvar "viewctr") "H" [color="red"]10[/color])
(command "zoom" "c" (getvar "viewctr") "M"[color="red"]2[/color])
Ok.thanks a lot . I will try your codes
(defun c:zc()
(setq ss (car (entsel "\nSelect  line:")))
(setq assolist (entget  ss))
(setq end1 (cdr(assoc 10 assolist)))
(command "zoom""C"end1 2000 "")
I try to zoom to one end of the selected line using above code.
It is working nicelly. but in some drawings (Test 2)the line dissapier
why that.
TEST1.dwg
TEST2.dwg
Mistake found mysels.
I have to set UCS to World
Also consider the zoomcenter method of the Application Object, e.g.:
(vla-zoomcenter (vlax-get-acad-object) (vlax-3D-point 1 2 3) 10.0)
  • 6 years later...
Thnx Lee Mac!
I did this:
(setq ZoomCeneter (vlax-3D-point (getpoint)))
(vl-propagate 'ZoomCenter)
If you use (vl-propagate 'ZoomCenter) you can use it in all opened docs
