Zoom to center
wimal
Please can someone explane me about the value , that request when we try to
zoom to center.
And why cant we activate snap on during this option.
Try these which working? red can be modified= magnification/ height
(command "zoom" "c" (getvar "viewctr") [color="red"]10[/color])
(command "zoom" "c" (getvar "viewctr") "H" [color="red"]10[/color])
(command "zoom" "c" (getvar "viewctr") "M"[color="red"]2[/color])
(defun c:zc()
(setq ss (car (entsel "\nSelect  line:")))
(setq assolist (entget  ss))
(setq end1 (cdr(assoc 10 assolist)))
(command "zoom""C"end1 2000 "")
I try to zoom to one end of the selected line using above code.
It is working nicelly. but in some drawings (Test 2)the line dissapier
why that.
TEST1.dwg
TEST2.dwg
  • 6 years later...
On 10/2/2014 at 12:48 AM, Lee Mac said:
Also consider the zoomcenter method of the Application Object, e.g.:
(vla-zoomcenter (vlax-get-acad-object) (vlax-3D-point 1 2 3) 10.0)
Thnx Lee Mac!
I did this:
(setq ZoomCeneter (vlax-3D-point (getpoint)))
(vl-propagate 'ZoomCenter)
If you use (vl-propagate 'ZoomCenter) you can use it in all opened docs
