Damon :) Posted October 6, 2014 Share Posted October 6, 2014 (edited) What is the best tool to use to modify an Attribute within a Block? Edited October 6, 2014 by Damon :) spelling error Quote Link to comment Share on other sites More sharing options...
RobDraw Posted October 6, 2014 Share Posted October 6, 2014 It depends on what you want to do with it. Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 6, 2014 Share Posted October 6, 2014 Some of the commands one could use are ATTIPEDIT, BATTMAN, and EATTEDIT. Here is a link to a list of other commands and system variables used to work with block attributes. The list is specific to AutoCAD 2015. Your version may vary. http://help.autodesk.com/view/ACDLT/2015/ENU/?guid=GUID-B98DE90E-779B-44F7-9694-A5CAB64B1C02 Quote Link to comment Share on other sites More sharing options...
SLW210 Posted October 6, 2014 Share Posted October 6, 2014 I moved your thread to the AutoCAD Drawing Management & Output Forum. Attach a drawing with an Attributed Block and explain what you wish to accomplish. Quote Link to comment Share on other sites More sharing options...
Ski_Me Posted October 6, 2014 Share Posted October 6, 2014 Open the file drawing of the block if the changes you want to make are permanent to the attributes. If you just want to make a change that's relative to the drawing the block is in then attedit is what you need. Start the command then select the block that has the attributes you need to change. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted October 7, 2014 Share Posted October 7, 2014 Sorry could not resist What is the best tool to use He is the guy who sits in the corner. Quote Link to comment Share on other sites More sharing options...
