Tony Mitchell 1983 Posted October 7, 2014 Share Posted October 7, 2014 Hi, I've created a dynamic block to create a block for doing planting plans. There is and attribute for number and an attribute for code. These need to appear in this order, but when the label is flipped, so is the order of the attributes. I added a second flip action to fix this, but ultimately, would like the second flip action to occur at the same time as the first. Does anyone have any ideas on how to achieve this, since flip parameters can't be chained? I've attached the block I'm talking about as it's hard to describe what I mean. Thanks.Planting Label.dwg Quote Link to comment Share on other sites More sharing options...
steven-g Posted October 7, 2014 Share Posted October 7, 2014 Remove the attributes from the flip selection set, and change the point parameter to chained. That should keep things in the right order, you will probably need to alter the position of the point parameter to get things to line up as you want. Quote Link to comment Share on other sites More sharing options...
Tony Mitchell 1983 Posted October 19, 2014 Author Share Posted October 19, 2014 Thanks Steven, I've tried playing with a point parameter but I can't get it to work. I'm not sure what actions to associate with it or how to use the chained parameter. I haven't used a point or chained parameter before. Quote Link to comment Share on other sites More sharing options...
steven-g Posted October 20, 2014 Share Posted October 20, 2014 Something like this Planting Label.dwg Quote Link to comment Share on other sites More sharing options...
