wrha Posted October 9, 2014 Share Posted October 9, 2014 I have problem to appload menu in cad 2014 it aploaded one time and when I close cad 2014 a day reopen I lost it even when I appload it before I close almost my lisp which it contains in menu it not working dose any one know that problem Quote Link to comment Share on other sites More sharing options...
BIGAL Posted October 10, 2014 Share Posted October 10, 2014 Are you meaning Menuload to load a menu if so make sure you got to the workspace option bottom right and force a save workspace, we have ours set to no save as a default, so next time start autocad a menu will not be there. Quote Link to comment Share on other sites More sharing options...
wrha Posted October 10, 2014 Author Share Posted October 10, 2014 Thank you but I need to understand the difference between cad 2011 as example and cad 2014 for that issue in cad 2011 it wasn't that problem but in cad 2014 not able to load the menu Quote Link to comment Share on other sites More sharing options...
tmelancon Posted October 10, 2014 Share Posted October 10, 2014 Sounds a lot like what I was experiencing. Type CUI and scroll to the problem menu, which should say (unresolved) on the side, and right click, select "browse". Navigate to the parent folder and reselect the menu file. Hit OK and this should resolve the constant unloading. Even if it doesnt say unresolved, try it, I am almost certain it will work because we were having the same exact problem. Should be a simple fix. Keep me posted. Quote Link to comment Share on other sites More sharing options...
wrha Posted October 11, 2014 Author Share Posted October 11, 2014 Could you send pictures because it's not clear for me Thank you Quote Link to comment Share on other sites More sharing options...
