Hello,
i've a question, i made 9 function (g1 g2 g3 m1 m2 m3 p1 p2 p3)
I want to call each of them in a mapcar function, the 9 functions are into a list in arg of my function :
Let see exemple of g1
(defun g1 (l) (if (eq (car l) 1) NIL (cons 1(cdr l))))
My list of function : (g1 g2 g3 m1 m2 m3 p1 p2 p3)
When i want to call them for a value in that function, it's not working, someone can help me please ?)
(defun newopen (felem lop) (mapcar (lambda (y) (y felem)) lop))
(newopen '(1 2 3) '(g1 g2 g3 m1 m2 m3 p1 p2 p3))
Edited by Shakto
hi shako, welcome to forum, read this 1st
http://www.cadtutor.net/forum/showthread.php?9184-Code-posting-guidelines
maybe typo error ?
lambda quote missing?
[color="red"][b]'[/b][/color](lambda...)
also
if list=
'(g1 g2 g3 m1 m2 m3 p1 p2 p3) ;
you need, (([color="red"]eval[/color] y) felem)
or just
([color="red"]list[/color] g1 g2 g3 m1 m2 m3 p1 p2 p3)
we don't know how the rest functions g2 g3 m2...etc working or have bugs?
Didn't know about the eval function, still not working with the function newopen :
(defun newopen (felem lop) (mapcar '(lambda (y) ((eval y) felem)) lop))
I have that bug error : FUNCALL : The argument (lambda y) ((eval y) felem)) isn't a function
The others functions g1 g2 g3 etc... are working :
(defun g2 (l) (if (eq (car l) 2) NIL (cons 2(cdr l))))
(defun g3 (l) (if (eq (car l) 3) NIL (cons 3(cdr l))))
(defun m1 (l) (if (eq (car l) 1) NIL (if (eq (cadr l) 1) NIL (if  (eq (car l) (cadr l)) NIL (cons (car l) (cons 1 (cddr l)))))))
(defun m2 (l) (if (eq (car l) 2) NIL (if (eq (cadr l) 2) NIL (if  (eq (car l) (cadr l)) NIL (cons (car l) (cons 2 (cddr l)))))))
(defun m3 (l) (if (eq (car l) 3) NIL (if (eq (cadr l) 3) NIL (if  (eq (car l) (cadr l)) NIL (cons (car l) (cons 3 (cddr l)))))))
(defun p1 (l) (if (eq (car l) 1) NIL (if (eq (caddr l) 1) NIL (if (eq (car l) (caddr l)) NIL (if (eq (cadr l) (caddr l)) NIL (append (list(car l)) (list(cadr l)) (cons 1 ())))))))
(defun p2 (l) (if (eq (car l) 2) NIL (if (eq (caddr l) 2) NIL (if (eq (car l) (caddr l)) NIL (if (eq (cadr l) (caddr l)) NIL (append (list(car l)) (list(cadr l)) (cons 2 ())))))))
(defun p3 (l) (if (eq (car l) 3) NIL (if (eq (caddr l) 3) NIL (if (eq (car l) (caddr l)) NIL (if (eq (cadr l) (caddr l)) NIL (append (list(car l)) (list(cadr l)) (cons 3 ())))))))
without eval
(defun newopen1 (felem lop) (mapcar '(lambda (y) ([color="red"]y[/color] felem)) lop))
(newopen1 '(1 2 3) ([color="blue"]list[/color] g1 g2 g3 m1 m2 m3 p1 p2 p3))
with eval:
(defun newopen2 (felem lop) (mapcar '(lambda (y) (([color="blue"][b]eval[/b][/color] y) felem)) lop))
(newopen2 '(1 2 3) [color="red"][b]'[/b][/color](g1 g2 g3 m1 m2 m3 p1 p2 p3))
This may explain: QUOTE
This is your return value?
;(nil (2 2 3) (3 2 3) nil nil (1 3 3) nil (1 2 2) nil)
Yes it's my return value.
I have errors with both of your function :
newopen1 => Error: The variable G1 is unbound.
newopen2 => Argument to apply/funcall is not a function: (LAMBDA (Y) ((EVAL Y) FELEM)).
maybe after version 2007 lambda needs to be optimized though without compile ?? :?
(defun newopen2 (felem lop) (mapcar ([color="blue"]function[/color](lambda (y) ((eval y) felem))) lop))
(newopen2 '(3 2 1) '(g1 g2 g3 m1 m2 m3 p1 p2 p3))
;((1 2 1) (2 2 1) nil (3 1 1) nil nil nil (3 2 2) nil)
Dunno :ouch:
Already tried that and it shows me : (eval y) must be a LAMBDA expression
As hanhphuc has suggested, the following is correct:
(defun newopen ( felem lop ) (mapcar '(lambda ( y ) ((eval y) felem)) lop))
In my testing:
_$ (newopen '(1 2 3) '(g1 g2 g3 m1 m2 m3 p1 p2 p3))
What software/method are you using to evaluate your code?
Are you entering the code at the AutoCAD 2014 command-line or in the VLIDE console?
Damn, i wanted to try my program on CLISP before AutoCAD
I was using CLISP 2.49 on windows >.
:ouch:
just for info, all these return '(1)
(cons 1 ()) ;<--- your code
(cons 1 nil)
(list 1)
'(1)
