Basomis Posted October 24, 2014 Share Posted October 24, 2014 (edited) I need some LISP routine which autonumbers distance between polygon vertices. Edited October 24, 2014 by Basomis Quote Link to comment Share on other sites More sharing options...
MSasu Posted October 24, 2014 Share Posted October 24, 2014 I will use for that the built-in QDIM command with an appropriate dimension style (that it, hide the arrows, extension and dimension lines); don't forget to set an adequate UCS first. After call QSELECT with a filter for dimensions with Measuring feature smaller than given value and remove them. This will also ensure that the result is associative. Quote Link to comment Share on other sites More sharing options...
Basomis Posted October 24, 2014 Author Share Posted October 24, 2014 For some weird reason QDIM seems not to work on AutoCad Map. It's a pity that the suggestion posted above doesn't solve the problem. This LISP routine would greatly help since it takes ages to place those distances between every vertex. Quote Link to comment Share on other sites More sharing options...
hanhphuc Posted October 24, 2014 Share Posted October 24, 2014 i'm not sure is it similar previous thread? The distance text is associative due to its actually a dimension without arrow looks like normal line object (similar mircea's idea) if just a distance? (defun c:test (/ p l e d var ) (setq l '("CMDECHO" "OSMODE" "DIMTIH" "DIMTOH" "DIMASSOC") var (mapcar 'getvar l) ) ;_ end of setq (mapcar 'setvar l '(0 0 0 0 2)) (if (setq e (car (entsel "\nPick polygon.. "))) ;[color="red"]<---LWPOLYLINE[/color] (setq p (mapcar 'cdr (vl-remove-if-not ''((x) (= (car x) 10)) (entget e))) p (if (= (cdr (assoc 70 (entget e))) 1) (append p (list (car p) (cadr p))) p ) ; if d (mapcar ''((a b) ([color="blue"]ppdim[/color] a b)) p (cdr p)) ) ;_ end of setq (princ "\nInvalid. ") ) ;_ end of if (mapcar 'setvar l var) (princ) ) ;_ end of defun ;little tweak from previous [color="red"]ldim[/color] function ;http://www.cadtutor.net/forum/showthread.php?89187-Not-Aligned-Not-Linear-Lengths-but-geometric-or-List-Length (defun [color="blue"]ppdim[/color] ( p1 p2 / mp sz ) ;hanhphuc 24/10/2014 (setq sz (* 0.05 (distance p1 p2)) mp (mapcar '(lambda (a b) (* 0.5 (+ a b))) p1 p2)) (vl-cmdf "_dimaligned" p1 p2 mp) ('((obj) (mapcar '(lambda (a b) (vlax-put obj a b)) '("Arrowhead1Type" "Arrowhead2Type" "extensionlineextend" "extensionlineoffset" "TextHeight" "TextInside" "VerticalTextPosition" "TextGap" ) (list 19 19 0. 0. sz 1 1 sz) ) (vlax-put-property obj 'TextFill :vlax-true) ) (vlax-ename->vla-object (entlast)) ) ) ;_ end of defun Quote Link to comment Share on other sites More sharing options...
Basomis Posted October 27, 2014 Author Share Posted October 27, 2014 The final result should look like this: The code posted above gives this result: Could anyone edit that routine so the final result looks like the one I need? Quote Link to comment Share on other sites More sharing options...
hanhphuc Posted October 27, 2014 Share Posted October 27, 2014 hi Basomis, try remove this line .. (vlax-put-property obj 'TextFill :vlax-true) .. Quote Link to comment Share on other sites More sharing options...
Basomis Posted October 27, 2014 Author Share Posted October 27, 2014 Awesome, it removed textfill. But I also want to remove the dimension line below the number. The numbers should round to 2 decimal places and every number should appear outside the polygon. Is it possible to implement these requirements? Quote Link to comment Share on other sites More sharing options...
hanhphuc Posted October 27, 2014 Share Posted October 27, 2014 The numbers should round to 2 decimal places (defun c:test (/ p l e d var ) (setq l '("CMDECHO" "OSMODE" "DIMTIH" "DIMTOH" "DIMASSOC" [color="red"]"DIMDEC"[/color]) var (mapcar 'getvar l) ) ;_ end of setq (mapcar 'setvar l '(0 0 0 0 2 [color="red"]2[/color])) ... ... The object actually is a dimension it uses current dimstyle, but if you wanna remove it, i think need to explode but it will become non associative. if just simple for placing text on polygon, either re-write new code or you can just search the web Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted October 27, 2014 Share Posted October 27, 2014 Add this into (ppdim) subfunction '("Arrowhead1Type" "Arrowhead2Type" "extensionlineextend" "extensionlineoffset" "TextHeight" "TextInside" "VerticalTextPosition" "TextGap" [color=red]"DimLine1Suppress" "DimLine2Suppress"[/color] ) (list 19 19 0. 0. sz 1 1 sz [color=red]1 1[/color]) HTH, M.R. Quote Link to comment Share on other sites More sharing options...
Basomis Posted October 28, 2014 Author Share Posted October 28, 2014 Great, the line below numbers don't appear anymore. The only thing left is how to make all numbers appear outside of the polygon? Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted October 28, 2014 Share Posted October 28, 2014 Among my lisps like autoaldim.lsp, I've found somewhere on www, pdim.lsp that has this option (Inside/Outside)... Now you'll have to combine what's already explained and this pdim.lsp... (defun c:pdim ( / ListClockwise-p ch plSet pLlst vLst oldOsn cAng cDis cPt ) (defun ListClockwise-p ( lst / z vlst ) (vl-catch-all-apply 'minusp (list (if (not (equal 0.0 (setq z (apply '+ (mapcar (function (lambda (u v) (- (* (car u) (cadr v)) (* (car v) (cadr u))) ) ) (setq vlst (mapcar (function (lambda (a b) (mapcar '- b a)) ) (mapcar (function (lambda (x) (car lst))) lst) (cdr (reverse (cons (car lst) (reverse lst)))) ) ) (cdr (reverse (cons (car vlst) (reverse vlst)))) ) ) ) 1e-6 ) ) z (progn (prompt "\n\nChecked vectors are colinear - unable to determine clockwise-p of list") nil ) ) ) ) ) (initget 1 "Outside Inside") (setq ch (getkword "\nChoose on which side to put dimensions [Outside/Inside] : ")) (princ "\n<<< Select LwPolyline(s) for dimensioning >>> ") (if (setq plSet (ssget '((0 . "LWPOLYLINE")))) (progn (setq pLlst (vl-remove-if 'listp (mapcar 'cadr(ssnamex plSet))) oldOsn (getvar "OSMODE") ); end setq (setvar "OSMODE" 0) (setvar "CMDECHO" 0) (command "_.undo" "_be") (foreach pl pLlst (setq vLst (mapcar '(lambda( x ) (trans x 0 1)) (mapcar 'cdr (vl-remove-if-not '(lambda( x ) (= 10 (car x))) (entget pl) ) ) ) ); end setq (if (equal (logand (cdr (assoc 70 (entget pl))) 1) 1) (setq vLst (append vLst (list (car vLst)))) ); end if (if (not (ListClockwise-p vLst)) (setq vLst (reverse vLst))) (while (< 1 (length vLst)) (setq cAng (angle (car vLst) (cadr vLst)) cDis (/ (distance (car vLst) (cadr vLst)) 2.0) ) ; (if (>= (caar vLst) (caadr vLst)) ; (setq cAng (- cAng pi)) ; ); end if (if (eq ch "Inside") (setq cPt (polar (polar (car vLst) cAng cDis) (- cAng (* 0.5 pi)) (* 2.5 (getvar "DIMTXT")))); end setq (setq cPt (polar (polar (car vLst) cAng cDis) (+ cAng (* 0.5 pi)) (* 2.5 (getvar "DIMTXT")))); end setq ); end if (command "_.dimaligned" (car vLst) (cadr vLst) cPt) (setq vLst (cdr vLst)) ); end while ); end foreach (command "_.undo" "_e") (setvar "OSMODE" oldOsn) (setvar "CMDECHO" 1) ); end progn ); end if (princ) ); end of c:pdim HTH Quote Link to comment Share on other sites More sharing options...
hanhphuc Posted October 30, 2014 Share Posted October 30, 2014 Add this into (ppdim) subfunction '("Arrowhead1Type" "Arrowhead2Type" "extensionlineextend" "extensionlineoffset" "TextHeight" "TextInside" "VerticalTextPosition" "TextGap" [color=red]"DimLine1Suppress" "DimLine2Suppress"[/color] ) (list 19 19 0. 0. sz 1 1 sz [color=red]1 1[/color]) HTH, M.R. c:pdim HTH, M.R. your pdim works fine ,but if the OP doesn't want the dimension line. my 2 cents: make unique "pdim" layer. After c:pdim done -> exploded "pdim" -> ssget all exploded lines -> (command "_erase" ss) *It's OP's choice which associative or not Quote Link to comment Share on other sites More sharing options...
hanhphuc Posted October 31, 2014 Share Posted October 31, 2014 Updated as OP request, put text outside polygon added 2 arguments cw : T / nil ; cw/ccw box : T / nil ; if T, Label with box ;ppdim.lsp , assosiative distance label (customized dimAligned) http://www.cadtutor.net/forum/showthread.php?89363-Automatic-distance-between-polygon-vertices&p=612627#post612627 (defun ppdim ( p1 p2 [color="red"]cw box[/color] / mp sz mx ); [color="red"]v1.1[/color] ;hanhphuc 31/10/2014 (setq vs '(nil (/ (getvar 'viewsize) (cadr (getvar 'screensize)))) sz (* 0.05 (distance p1 p2)) mp (mapcar '(lambda (a b) (* 0.5 (+ a b))) p1 p2) ) (vl-cmdf "_dimaligned" p1 p2 mp) ('((obj) (mapcar '(lambda (a b) (vlax-put obj a b)) '("Arrowhead1Type" "Arrowhead2Type" "extensionlineextend" "extensionlineoffset" "TextHeight" "TextInside" "VerticalTextPosition" "TextGap" [color="red"]"DimLine1Suppress" "DimLine2Suppress"[/color] ;<---[color="blue"] "line" visibility, thanks marko [/color]:-) ) (list 19 19 0. 0. sz 1 (if cw 1 2) ((if box - +) sz) 1 1 );((if cw + -) sz) ) (vlax-put-property obj 'TextFill [color="red"]:vlax-true[/color]) ;<--[color="blue"] text masked: [/color] [color="red"]1[/color] [color="blue"]or[/color] [color="red"]0[/color] ) (vlax-ename->vla-object (entlast)) ) ) ;_ end of defun (defun c:test (/ p l e d var) ;v1.1 (setq l '("CMDECHO" "OSMODE" "DIMTIH" "DIMTOH" "DIMASSOC" "DIMDEC") var (mapcar 'getvar l) ) ;_ end of setq (mapcar 'setvar l '(0 0 0 0 2 2)) (if (setq e (car (entsel "\nPick polygon.. "))) ;<---LWPOLYLINE (setq p (mapcar 'cdr (vl-remove-if-not ''((x) (= (car x) 10)) (entget e))) p (if (= (cdr (assoc 70 (entget e))) 1) (append p (list (car p) (cadr p))) p ) ; if cw (LM:ListClockwise-p p) d (mapcar ''((a b) (ppdim a b (cond ((and (minusp (cos (angle a b))) (not cw)) t) ((and (minusp (cos (angle a b))) cw ) nil) (t cw) ) ;_ end of cond [color="red"][b] t [/b][/color] ;<------- [color="blue"][color="red"]t [/color]= boxed / [color="red"]nil [/color]= normal[/color] , [color="blue"]here to change boxed setting ![/color] ) ) p (cdr p) ) ;_ end of mapcar ) ;_ end of setq (princ "\nInvalid. ") ) ;_ end of if (mapcar 'setvar l var) (princ) ) ;_ end of defun ;; coutesy & reference ;; List Clockwise-p - Lee Mac ;; Returns T if the point list is clockwise oriented http://www.lee-mac.com/mathematicalfunctions.html (defun LM:ListClockwise-p ( lst ) (minusp (apply '+ (mapcar (function (lambda ( a b ) (- (* (car b) (cadr a)) (* (car a) (cadr b))) ) ) lst (cons (last lst) lst) ) ) ) ) It still has minor bug can't fix, beyond my capability Quote Link to comment Share on other sites More sharing options...
