AIberto Posted October 26, 2014 Share Posted October 26, 2014 The following code sources from XDCAD.ORG , Author is Free-Lancer ;;Set Xrecord ;;bbs.xdcad.org ;;Author:Free-Lancer (defun Obj:SetXrecord (obj name values / _setxrecord xlst xrec dicts xd xt) (defun _setxrecord (obj lst) (vla-setxrecorddata obj (list->vbarray (mapcar 'car lst) vlax-vbinteger) (list->vbarray (mapcar 'cdr lst) vlax-vbvariant) ) ) (if (= (vla-get-objectname obj) "AcDbDictionary") (progn (vlax-for d obj (if (and (= (vla-get-objectname d) "AcDbXrecord") (= (strcase (vla-get-name d)) (strcase name)) ) (setq xrec d) ) ) (if xrec (progn (vla-getxrecorddata xrec 'xt 'xd) (if xt (_setxrecord xrec (append (mapcar '(lambda (x y) (cons x y) ) (safearray-value xt) (mapcar 'variant-value (safearray-value xd)) ) values ) ) (_setxrecord xrec values) ) ) (progn (setq xrec (vla-addxrecord obj name)) (_setxrecord xrec values) ) ) ) (if (= (vla-get-hasExtensionDictionary obj) :vlax-true) (progn (setq dicts (vla-GetExtensionDictionary obj)) (vlax-for dict dicts (if (and (= (vla-get-objectname dict) "AcDbXrecord") (= (strcase (vla-get-name dict)) (strcase name)) ) (setq xrec dict) ) ) (if xrec (progn (vla-getxrecorddata xrec 'xt 'xd) (_setxrecord xrec (append (mapcar '(lambda (x y) (cons x y) ) (safearray-value xt) (mapcar 'variant-value (safearray-value xd)) ) values ) ) ) ) ) (progn (setq dict (vla-getextensiondictionary obj) xrec (vla-addxrecord dict name) ) (_setxrecord xrec values) ) ) ) ) ;;Get Xrecord ;; Get Xrecord ;;bbs.xdcad.org ;;Author:Free-Lancer (defun Obj:GetXrecord (obj name / e dicts xd xt lst _getxrecord) (defun _getxrecord (dc / xt xd) (if (= (vla-get-objectname dc) "AcDbXrecord") (progn (vla-getxrecorddata dc 'xt 'xd) (if (and xt xd) (setq lst (cons (cons (vla-get-name dc) (mapcar '(lambda (x y) (cons x y)) (safearray-value xt) (mapcar 'variant-value (safearray-value xd)) ) ) lst ) ) (setq lst (cons (vla-get-name dc) lst)) ) ) ) ) (if (= (vla-get-objectname obj) "AcDbDictionary") (vlax-for dict obj (_getxrecord dict)) (if (= (vla-get-hasExtensionDictionary obj) :vlax-true) (progn (setq dicts (vla-GetExtensionDictionary obj)) (vlax-for dict dicts (_getxrecord dict)) ) ) ) (if (= name "*") lst (vl-remove-if-not '(lambda (x) (= (strcase (car x)) (strcase name))) lst ) ) ) ;;Delete Xrecord ;;bbs.xdcad.org ;;Author:Free-Lancer (defun obj:DeleteXrecord (obj name /) (if (= (vla-get-objectname obj) "AcDbDictionary") (vlax-for d obj (if (= (vla-get-objectname d) "AcDbXrecord") (if (= name "*") (vla-delete d) ) (if (= (strcase (vla-get-name d)) (strcase name)) (vla-delete d) ) ) ) (if (vla-get-hasextensiondictionary obj) (vlax-for d (vla-getextensiondictionary obj) (if (= (vla-get-objectname d) "AcDbXrecord") (if (= name "*") (vla-delete d) ) (if (= (strcase (vla-get-name d)) (strcase name)) (vla-delete d) ) ) ) ) ) ) ;;Replace Xrecord ;;bbs.xdcad.org ;;Author:Free-Lancer (defun OBJ:ReplaceXrecord (obj name vars / oldvars lst tf) (if (setq lst (obj:getxrecord obj name)) (progn (setq oldvars (mapcar 'car vars) lst (mapcar '(lambda (x / ll nx) (if (setq ll (vl-member-if '(lambda (a) (equal a x 1e-3)) oldvars ) ) (progn (setq nx (cons (car x) (cadr (assoc (car ll) vars))) tf t ) (setq vars (vl-remove (car ll) vars)) nx ) x ) ) lst ) ) (if tf (obj:setxrecord obj name lst) ) t ) ) ) ;;Remove Xrecord ;;bbs.xdcad.org ;;Author:Free-Lancer (defun Obj:RemoveXrecord (obj name vars / lst) (if (setq lst (obj:getxrecord obj name)) (progn (mapcar '(lambda (x / el) (if (setq el (vl-member-if '(lambda (a) (equal (cdr a) x 1e-3)) lst ) ) (setq lst (vl-remove (car el) lst) tf t ) ) ) vars ) (if tf (obj:setxrecord obj name lst) ) t ) ) ) Quote Link to comment Share on other sites More sharing options...
